Pioneer BD-RW BDR-209M - UHD possible?
BubberDucky
Post by BubberDucky »
can anyone help me on making my Blu Ray Drive able to backup UHD Blu Ray discs?
Currently, it does not recognize them.
If there are any options such as flashing the drive, any help is much appreciated.
See the makemkv info on the drive below:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Serial number: [redacted]
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8600
Firmware version: 1.20/ID60
Re: Pioneer BD-RW BDR-209M - UHD possible?
Yes email me for the flasher see below
R22D22
Post by R22D22 »
I've got the same problem, can you help me that can I flash the drive to use UHD, please?
Thank you in advance :)
