Pioneer BDR-UD03 UHD possibility
rasheed2222
Re: Pioneer BDR-UD03 UHD possibility
Post by rasheed2222 »
Coopervid wrote:
Sun May 05, 2024 10:48 am
ZeroCool1974_BR wrote:
Sat May 04, 2024 7:22 pm
Hi Coopervid,
I've this same drive but i can't find any new firmware. Could you help me?
PIONEER BD-RW   BDR-UD03 1.03-ID19
Check your PM.
Can you send me your blessing DM to help make my Verbatim 43890 readh UHD :)
rafa00agent wrote:
Mon Aug 26, 2024 10:16 pm
Hi Coopervid, could you please DM me with the instruction to make my drive UHD compatible?
Informações da Unidade
Nome do dispositivo do SO: H:
Perfil atual: BD-RE
Fabricante: ASUS
Produto: SBW-06D5H-U
Revisão: E101
Número de série: [redacted]
Data do Firmware: 2018-08-22
Sinalizações de criptografia bus: 1B
Drive platform: RS8511
Firmware version: E101/ID26
Thanks in advance!
Read your PM.
rasheed2222 wrote:
Tue Aug 27, 2024 6:59 am
Hi Coopervid,
Check your PM.
Pm sent.
Again a warning to all who ask to get their drives fixed. I write immediate responses and then the PM just sits there and isn't read. PMs will expire one week after being sent and then you can look and try elsewhere. Curse words follow here :evil: :evil: :evil: :evil:
McZion
Post by McZion »
Hi Coopervid!
I was checking some forum topics and different instructions and came to this topic, where I see I can have my Pioneer BDR-US03 (in ASUS SBW-06D5H-U enclosure) flashed to be UHD friendly.
I would greatly appreciate it if you could send me the firmware I need to enable UHD disk reading. Here is my info:
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: [redacted]
Firmware date: 2018-08-22
Also, I would like to clarify - in case of problems, will it be possible to return to my drive's original firmware after flashing the UHD-friendly firmware?
Thank you in advance!
PS: I have enabled notifications, so I will for sure see your response :)
TheVM
Post by TheVM »
Coopervid wrote:
Tue Aug 27, 2024 5:31 pm
Check your PM.
Pm sent.
Hi Coopervid!
I stumbled on this topic and i'm wondering if you could help me flash my drive:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 35
Firmware version: 1.14
nm610
Post by nm610 »
Hello, I too have a BD-RW BDR-UD03 and am looking for a flash, will check my pms. Thank you for the work you are doing :D
Current profile: DVD-ROM
Revision: 1.14
SneakyGit
Post by SneakyGit »
Coopervid wrote:
Thu May 02, 2024 10:45 am
PM sent.
My apologies,
Apparently I missed your response, and you have deleted your PM.
raven9mm
Post by raven9mm »
Hi Coopervid, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: H:
Product: BD-RW BDRUD03AS
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID23
SneakyGit wrote:
Sat Aug 31, 2024 7:57 pm
PM sent.
My apologies,
I told you so and others. I would have a mailbox full with unread messages. Check the forum and pay 25 bucks to Billy or Marty.
raven9mm wrote:
Sun Sep 01, 2024 7:39 am
OS device name: H:
Revision: 1.10
Serial number:
PM is coming.
TheVM
Post by TheVM »
Coopervid wrote:
Sun Sep 01, 2024 6:43 pm
OS device name: H:
Revision: 1.10
Serial number:
PM is coming.
hehe I got triggered by a notification, but that was a response to somebody else :roll:
McZion wrote:
Wed Aug 28, 2024 10:02 pm
Hi Coopervid!
OS device name: F:
Manufacturer: ASUS
Revision: E101
Check your PM.
TheVM wrote:
Thu Aug 29, 2024 11:09 pm
Pm sent.
Hi Coopervid!
Revision: 1.14
Check your PM.
nm610 wrote:
Sat Aug 31, 2024 2:09 am
Revision: 1.14
PM sent.
