Is my BU40N firmware OK ?
georgesgiralt
Post by georgesgiralt »
A friend of mine gave me this one :
Informations lecteur
Nom du lecteur SE : /dev/sr0
Fabricant : HL-DT-ST
Produit : BD-RE BU40N
Révision : 1.03
Numéro de série : XXXXXXXXXXXXXX
Date micrologiciel : 2118-10-24 19:34
Marqueurs d'encryptage bus : 17
Version AACS la plus haute : 77
Firmware version: 1.03
Is it the "BU40N 1.03MK" firmware ? There is no MK anywhere....
Sorry if this is a dumb question.
Re: Is my BU40N firmware OK ?
Does it rip UHD discs if so it's fine
georgesgiralt
I did not try it yet since I do not own any 4K BD.
georgesgiralt wrote: Tue Aug 27, 2024 3:58 pm Hello,
Révision : 1.03
Yes it is. That firmware is in the "OLD" folder.
Révision : 1.03
If ithe firmware type is "Patched" then it is a MK firmware. You are good to go. Start ripping!
georgesgiralt
Thank you all ! I couldn't sleep ;-)
