Can you send me your blessing DM to help make my Verbatim 43890 readh UHDCoopervid wrote: Sun May 05, 2024 10:48 amCheck your PM.ZeroCool1974_BR wrote: Sat May 04, 2024 7:22 pm Hi Coopervid,
I've this same drive but i can't find any new firmware. Could you help me?
PIONEER BD-RW BDR-UD03 1.03-ID19
Pioneer BDR-UD03 UHD possibility
rasheed2222
Re: Pioneer BDR-UD03 UHD possibility
Read your PM.rafa00agent wrote: Mon Aug 26, 2024 10:16 pm Hi Coopervid, could you please DM me with the instruction to make my drive UHD compatible?
Informações da Unidade
Nome do dispositivo do SO: H:
Perfil atual: BD-RE
Fabricante: ASUS
Produto: SBW-06D5H-U
Revisão: E101
Número de série: [redacted]
Data do Firmware: 2018-08-22
Sinalizações de criptografia bus: 1B
Drive platform: RS8511
Firmware version: E101/ID26
Thanks in advance!
Pm sent.rasheed2222 wrote: Tue Aug 27, 2024 6:59 amCan you send me your blessing DM to help make my Verbatim 43890 readh UHDCoopervid wrote: Sun May 05, 2024 10:48 amCheck your PM.ZeroCool1974_BR wrote: Sat May 04, 2024 7:22 pm Hi Coopervid,
PIONEER BD-RW BDR-UD03 1.03-ID19![]()
Again a warning to all who ask to get their drives fixed. I write immediate responses and then the PM just sits there and isn't read. PMs will expire one week after being sent and then you can look and try elsewhere. Curse words follow here
McZion
Hi Coopervid!
I was checking some forum topics and different instructions and came to this topic, where I see I can have my Pioneer BDR-US03 (in ASUS SBW-06D5H-U enclosure) flashed to be UHD friendly.
I would greatly appreciate it if you could send me the firmware I need to enable UHD disk reading. Here is my info:
Also, I would like to clarify - in case of problems, will it be possible to return to my drive's original firmware after flashing the UHD-friendly firmware?
Thank you in advance!
PS: I have enabled notifications, so I will for sure see your response
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: [redacted]
Firmware date: 2018-08-22
TheVM
Hi Coopervid!Coopervid wrote: Tue Aug 27, 2024 5:31 pmPm sent.rasheed2222 wrote: Tue Aug 27, 2024 6:59 amCan you send me your blessing DM to help make my Verbatim 43890 readh UHD![]()
I stumbled on this topic and i'm wondering if you could help me flash my drive:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 35
Firmware version: 1.14
No disc inserted-
nm610
Hello, I too have a BD-RW BDR-UD03 and am looking for a flash, will check my pms. Thank you for the work you are doing
Current profile: DVD-ROM
Revision: 1.14
Revision: 1.14
SneakyGit
My apologies,
Apparently I missed your response, and you have deleted your PM.
raven9mm
Hi Coopervid, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: H:
Product: BD-RW BDRUD03AS
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID23
OS device name: H:
Revision: 1.10
Serial number:
I told you so and others. I would have a mailbox full with unread messages. Check the forum and pay 25 bucks to Billy or Marty.
PM is coming.raven9mm wrote: Sun Sep 01, 2024 7:39 am Hi Coopervid, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: H:
Revision: 1.10
Serial number:
TheVM
hehe I got triggered by a notification, but that was a response to somebody elseCoopervid wrote: Sun Sep 01, 2024 6:43 pmPM is coming.raven9mm wrote: Sun Sep 01, 2024 7:39 am Hi Coopervid, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: H:
Revision: 1.10
Serial number:
Check your PM.McZion wrote: Wed Aug 28, 2024 10:02 pm Hi Coopervid!
Also, I would like to clarify - in case of problems, will it be possible to return to my drive's original firmware after flashing the UHD-friendly firmware?Code: Select all
Drive Information OS device name: F: Manufacturer: ASUS Product: SBW-06D5H-U Revision: E101 Serial number: [redacted] Firmware date: 2018-08-22 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: E101/ID26 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PS: I have enabled notifications, so I will for sure see your response![]()
Check your PM.TheVM wrote: Thu Aug 29, 2024 11:09 pmHi Coopervid!Coopervid wrote: Tue Aug 27, 2024 5:31 pmPm sent.rasheed2222 wrote: Tue Aug 27, 2024 6:59 am
Drive Information OS device name: D: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [redacted] Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 35 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
PM sent.nm610 wrote: Sat Aug 31, 2024 2:09 am Hello, I too have a BD-RW BDR-UD03 and am looking for a flash, will check my pms. Thank you for the work you are doing![]()
Revision: 1.14
