Thanks worked perfectly =)Coopervid wrote: ↑Mon Aug 05, 2024 5:22 pmPM sent.vidgonio wrote: ↑Mon Aug 05, 2024 3:31 amHi, can you help me?
My drive info is the following:
OS device name: H:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: [redacted]
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Thanks for any help you might provide in advance =)
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Any chance to make it read 4K discs? I snagged this one during a trip to Germany earlier this year.Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 76
Firmware version: 1.14
PM is coming.TheoDW wrote: ↑Mon Aug 12, 2024 7:31 pmAny chance to make it read 4K discs? I snagged this one during a trip to Germany earlier this year.Drive Information
Revision: 1.14
InstantCake
Hello
I recently got a Verbatim 43890 Slimline Blu-ray writer which is recognized as a BD-RW BDR-UD03 in MakeMKV.
Here is the log:
Any chance to get 4k UHD working with this one?
Thanks in advance
Here is the log:
Revision: 1.14
Unrestricted read speed: YesThanks in advance
Read your PM.InstantCake wrote: ↑Tue Aug 13, 2024 8:55 pmHello
Here is the log:
Any chance to get 4k UHD working with this one?Code: Select all
Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [redacted] Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Thanks in advance
InstantCake
Much obliged and thank you very much. e: Thanks mods for redacting my serial no.
Hi Coopervid, I recently picked up a Verbatim 43891 with the details below:
I am looking to get it to read UHD discs. Is this possible with the patch? If yes can I please get details on it as well.
Thanks so much for all the help.
Ps sorry I'm not sure how to do the code thing yet as new to this page. Any advice here to will be greatly appreciated.
Revision: 1.05
Serial number:
Firmware date: 2015-11-24
Highest AACS version: 60
Drive platform: RS8510
Firmware version: 1.05
Revision: 1.05
Serial number:
PM sent.pog84 wrote: ↑Fri Aug 16, 2024 11:03 amHi Coopervid, I recently picked up a Verbatim 43891 with the details below:
Revision: 1.05
Serial number:
PegasusPilot
Verbatim 71094/BDR-UD03
Good evening folks,
Long-time lurker, first time poster.
I’ve recently gotten into backing up all of my movies, which is expanding to UHDs, and I have several slim external Verbatim drives I’ve been using (model 71094). I see that quite a few other folks have received help with flashing the firmware on their BDR-UD03 to a UHD-compatible variant, and I want to ask if someone would be willing to help.
My drive stats are as follows:
Revision: 1.14
Highest AACS version: 81
LibreDrive stats as follows:
I’ve looked through all of the other posts in this thread and my equipment matches what everyone else who’ve been PM’d have posted about.
I understand the importance of reading/following the tutorial for flashing the firmware to BDR-UD04. I’ve watched both of the walkthroughs for the “Ultra Hax0R” flashing guide and I’m comfortable with CP/PS. I also noted that in the Ultimate Flashing Guide it’s recommended to only use Marty’s SDF GUI, but I’m also comfortable with using the CLI and being mindful of what I’m executing.
I’ll be monitoring this thread and I’ll be watching my PMs if someone has the time and would be able to help.
Thank you in advance!
Revision: 1.14
Cheers friend(s)
Hi Coopervid - it appears you may be able to help me out.
How can I get access to UHD? Apologies if I am reaching out in the wrong part of the forum
Revision: 1.14
Serial number: redacted (realized you are supposed to do this)
Highest AACS version: 68
Revision: 1.14
Re: Verbatim 71094/BDR-UD03
PM sent.PegasusPilot wrote: ↑Sat Aug 17, 2024 4:01 amGood evening folks,
Revision: 1.14
PegasusPilot
Coopervid; message received and files downloaded. I’ll follow your instructions and flash my drive in a little bit today.Coopervid wrote: ↑Sun Aug 18, 2024 10:18 amPM sent.PegasusPilot wrote: ↑Sat Aug 17, 2024 4:01 amGood evening folks,
Revision: 1.14
Thank you for your assistance and willingness to help us newbies; we sincerely appreciate your help and “taking us under your wing”!
Cheers friend(s)
Complete newbie here - can anyone please help me getting my drive to recognise UHD disks - the drive simply ejects them after a while. I've tested on both Windows and Unix (MacOS). Here are my drive information. 1000 times thanks in advance
Revision: 1.10
Firmware date: 2017-04-18
Firmware version: 1.10
Revision: 1.10
Just email me that info see below for flasherPenguin wrote: ↑Thu Aug 22, 2024 12:24 pmComplete newbie here - can anyone please help me getting my drive to recognise UHD disks - the drive simply ejects them after a while. I've tested on both Windows and Unix (MacOS). Here are my drive information. 1000 times thanks in advance![]()
Revision: 1.10
rafa00agent
Hi Coopervid, could you please DM me with the instruction to make my drive UHD compatible?
Informações da Unidade
Nome do dispositivo do SO: H:
Perfil atual: BD-RE
Fabricante: ASUS
Produto: SBW-06D5H-U
Revisão: E101
Número de série: [redacted]
Data do Firmware: 2018-08-22
Sinalizações de criptografia bus: 1B
Thanks in advance!
Perfil atual: BD-RE
Fabricante: ASUS
Revisão: E101
Thanks in advance!
