Default Track Selection "matches if Nth (or bigger) track..."
taylorwmj
Post by taylorwmj »
Does the
matches if Nth (or bigger) track of the same type and language
work at all for selection? I've gone back through the posts and it appears it's perhaps never worked?
Mike or woodstock -- any updates if this is ever going to be fixed?
This is huge future to help with selection logic for selecting the best/top language track on titles where default language is not available (foreign titles), but the top selection is likely the one you want to select.
Open to other ideas as well as how to select the top non-default language audio track.
Re: Default Track Selection "matches if Nth (or bigger) track..."
I could not say - I simply tell MakeMKV to pull EVERY language track, audio and subtitle, and sort it out when processing through handbrake.
taylorwmj
Post by taylorwmj »
Yeah I can understand that. Unfortunately in my case I don't run anything through handbrake. I keep everything as is from MMKV. This sort of flag would be helpful with TV series only in foreign language so we don't have to go through multiple titles and select what we need.
fisibe5215
Post by fisibe5215 »
Did you find a solution to only select one track per language automatically?
taylorwmj
Post by taylorwmj »
No -- never did. Sorry...
