Sorry! Can't help without knowing the drive platform. You might have a Pioneer or a LG or even something else.centrafl wrote: Thu Aug 08, 2024 4:02 pm Libre drive information doesn't pull up for that drive for some reason, but for other drives it does. Does that mean its not supported?
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
centrafl
just to confirm, even if its an ASUS SBW-06D2X-U, it can still be a Pioneer or LG? If that's the case do you know why the Libre Drive info doesn't show up for this?
Sorry, I don't. I tried Google for your firmware but wasn't successful.centrafl wrote: Thu Aug 08, 2024 6:37 pm just to confirm, even if its an ASUS SBW-06D2X-U, it can still be a Pioneer or LG? If that's the case do you know why the Libre Drive info doesn't show up for this?
Buy a new one. Tell us your country of residence and if you want an external or 5,25" drive.centrafl wrote: Thu Aug 08, 2024 6:37 pm just to confirm, even if its an ASUS SBW-06D2X-U, it can still be a Pioneer or LG? If that's the case do you know why the Libre Drive info doesn't show up for this?
centrafl
USA, prefer external but whichever is cheaper, can always use a usb to sata adapter.
So read your PM.centrafl wrote: Thu Aug 08, 2024 9:25 pm USA, prefer external but whichever is cheaper, can always use a usb to sata adapter.
Vesprito
Hello i have the same drive can i also update the firmware?
Here's my drive information:
Laufwerksinformation
OS-Gerätename: H:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: [redacted]
Firmware-Datum: 2017-04-18
Firmware version: ID22
OS-Gerätename: H:
Produzent: ASUS
Revision: 1.10
Read your PM.Vesprito wrote: Sat Aug 17, 2024 7:00 pm Hello i have the same drive can i also update the firmware?
OS-Gerätename: H:
Produzent: ASUS
Revision: 1.10
Vesprito
Wow worked without problems thank you very muchCoopervid wrote: Sun Aug 18, 2024 10:14 amRead your PM.Vesprito wrote: Sat Aug 17, 2024 7:00 pm Hello i have the same drive can i also update the firmware?
OS-Gerätename: H:
Produzent: ASUS
Revision: 1.10
wegionl
I have the same drive, please also help me.
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Highest AACS version: 81
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
PM sent.wegionl wrote: Mon Aug 19, 2024 9:40 am I have the same drive, please also help me.
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
wegionl
Coopervid wrote: Mon Aug 19, 2024 4:40 pmPM sent.wegionl wrote: Mon Aug 19, 2024 9:40 am I have the same drive, please also help me.
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
It works!! Thank you so much!
mkvfan2
Same drive, requesting help:
OS device name: /dev/sr0 (Linux, can switch to Windows if needed)
Current profile: DVD-ROM
Manufacturer: ASUS
Revision: 1.10
Thank you in advance!
Manufacturer: ASUS
Revision: 1.10
PM sent.mkvfan2 wrote: Thu Aug 22, 2024 11:59 am Same drive, requesting help:
Manufacturer: ASUS
Revision: 1.10
mkvfan2
You legend, thanks a lot!
