Another dumb question
georgesgiralt
Post by georgesgiralt » Tue Feb 27, 2024 11:33 am
Hi Guys,
Is it possible and if yes how change or suppress the region code in a DVD ISO image ?
Thanks in advance for your help and advices !
Have a nice and bright day.
PegasusPilot
Re: Another dumb question
Post by PegasusPilot » Wed Aug 21, 2024 5:07 am
Hey georgesgiralt,
Did you ever get any assistance from someone about this? I don’t see any responses below your original request, and you got me thinking about this too now. I did a not-insignificant amount of searching myself, including on the doom9 forum, but ALL of the info I could find only explained the different media region codes themselves and (potentially) how to circumvent the region check on the device.
Since home-made movies are all Region 0 (region-free) and all other region codes (I believe) are only found on officially licensed/professionally-manufactured sourced disks, my best guess is that the region is hard-coded into the disk itself prior to/during burning. I have no way to prove that (so I might be making an ass of myself) and I can’t find any information regarding the disks, besides that the region code is read by the player/drive at initial spin-up and will either allow further loading or kill the read operation. Occam’s Razor, or just bullshit?
Regardless, I haven’t experienced an issue with inability to play a backed-up DVD copy due to region coding yet (all of my drives are region 1); I’m going to further assume that this has to do with LibreDrive reading the raw data from your disk without regarding any hard-coded region designation, or that it’s not affected because the backed-up ISO won’t have this region designation anyways.
Thoughts?
Cheers friend(s)
Post by dcoke22 » Wed Aug 21, 2024 3:24 pm
https://en.wikipedia.org/wiki/DVD_region_code
^ that gives a reasonable Wikipedia level of explanation. The short, short version is DVD players have firmware that checks a well known location on a DVD for the region code programmed onto the disc. If the disc is outside the region the player is set to, the player refuses to play the disc (even though technically it could play it just fine).
LibreDrive functionality in MakeMKV (with proper optical drives) allows MakeMKV to ignore this behavior and produce .mkv files which don't have the concept of region coding.
I can't say either way about what MakeMKV does with region coding when it produces an .iso backup of a DVD. I would guess it does not change it in any way. There probably is some other software that can remove the region coding from a DVD .iso backup, but I don't know what it is.
georgesgiralt
Post by georgesgiralt » Sun Aug 25, 2024 12:10 pm
Changing the region code involve changing a file in the file tree of the DVD. Which is read only.
So if you know how to change a read only file on a read only file system, bob's your uncle....
exitguy
Post by exitguy » Sun Aug 25, 2024 12:22 pm
And if you don't know then Martha is your aunt .....
Rojma
Post by Rojma » Sat Sep 14, 2024 12:44 am
If you use the MakeMKV backup function to backup a DVD to ISO, it will remove copy protection/encryption (CSS) and change the region to all regions (1, 2, 3, 4, 5, 6, 7, 8). However, it doesn't remove RCE protection, although I don't know if this matters since it is set to all regions. To remove RCE protection or other type of protections like PUOs (prohibited user operations - think not being able to skip warning screens or previews), you can use DVD Decrypter. DVD Decrypter isn't very good at removing copy protection from most modern DVDs (it hasn't been updated like in 20 years), but that is what MakeMKV is for. Once you remove the copy protection, then you can make additional modifications with DVR Decrypter since the resulting ISO from MakeMKV is no longer protected.
If you have existing backed up ISOs that were created with something other than MakeMKV, assuming they don't have any type of copy protection, then you have the following options:
1) Load the ISO into MakeMKV and then use the back up function of MakeMKV to create a new ISO that is all regions.
2) Load the ISO into DVD Decypter, make sure the remove RC and RCE protections options are enabled, and the create a new ISO.
Rojma
Post by Rojma » Sat Sep 14, 2024 12:53 am
FYI I just read up on RCE (region code enhanced) protection vs just RC (region protection) protection and it looks like RCE protection adds an additional layer in a case where you are using a region-free or multi-region player. I guess it prohibits playing the disc on a region free or multi-region player? If your "player" is set to only one specific region, then it shouldn't matter and the RCE protection should be irrelevant.
