BDR-XD07 help with UHD compatibility
bakeractive
Post by bakeractive » Sat Aug 24, 2024 4:57 pm
Hello! new user here, can you please provide info on flashing my drive to be compatible with UHD disks?
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: [redacted]
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8D30
Firmware version: 1.03
Re: BDR-XD07 help with UHD compatibility
Post by dcoke22 » Sat Aug 24, 2024 7:05 pm
Generally speaking, don't flash Pioneer drives as you're likely to make them incompatible.
Does your drive not work with a UHD? Your post suggests LibreDrive status is Enabled.
Post by Coopervid » Sat Aug 24, 2024 7:16 pm
Revision: 1.03
Read your PM.
bakeractive
Post by bakeractive » Sat Aug 24, 2024 7:22 pm
I bought it thinking it was a UHD drive with old firmware then noticed too late that no UHD label on box lol. I've tried UHD disks, but no luck. But searching this forum some members may be able to help flash it, only through a private channel? I have an LG BP60nb10 that I am able to rip 4k and watch, through MK firmware. it was bought on amazon idk if I got lucky on the version but its a noisy one! Pioneer is recommended... How many non UHD drives pioneer drives are able to get UHD working through some work? The UHD guide skips on this knowledge.
Post by Coopervid » Sun Aug 25, 2024 9:31 am
The only new slim drive that is UHD capable on the free market is a Verbatim 43888. You can try asmcom as a seller here and get a pre-flashed newer type Pioneer model.
