error message using virtual drive
CarlFredricksen
#1 Post by CarlFredricksen » Fri Aug 23, 2024 7:30 am
I downloaded MakeMKV today for the first time to test it. I put an ISO file of a Blu-ray into the virtual drive (clone drive) and wanted to open it with MakeMKV. But I get an error message:
AACS VID cannot be read - most likely the AACS host certificate is cancelled by your drive
The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted
Opening the disc failed
With other programmes such as AnyMP4 or Leawo Prof. Media everything works without any problems.
What can I do to make MakeMKV work?
Re: error message using virtual drive
#2 Post by dcoke22 » Sat Aug 24, 2024 2:37 pm
Do you have an actual optical drive? Does MakeMKV work with a disc in the drive?
Ezatoka
#3 Post by Ezatoka » Sun Aug 25, 2024 12:52 am
Is it any different, if you open the ISO file directly with MakeMKV? Just go File -> Open Files and navigate to the ISO.
CarlFredricksen
#4 Post by CarlFredricksen » Mon Aug 26, 2024 12:08 pm
I only have a DVD drive on my PC. Would that also work?
It makes no difference whether I open the ISO file via the virtual drive or select it directly.
#5 Post by dcoke22 » Mon Aug 26, 2024 2:59 pm
A DVD drive will only read DVDs (and probably audio CDs). It won't work with a blu-ray, which uses a different laser wavelength than DVDs.
CarlFredricksen
#6 Post by CarlFredricksen » Wed Aug 28, 2024 10:01 am
I know. I only wrote it because you asked if I have a Blu-ray drive on my PC. I have one on another, create ISO files there and then edit them on my Office PC, where MakeMKV is installed.
