Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
I am after an internal slimline sata drive in the UK.
Would rather a slimline internal drive as it avoids me replacing my computer or adding another usb box to my desk!
Thanks, G
Thanks, G
I have the same interest/question.
I am in the US
An external would be preferred but I can be flexible if an internal 5 1/4" SATA would be better
I am in the US
in the usa i have 5.25 pioneers with old fw see below
What's the best external drive to get for ripping dvd and bluray? On a bit of a budget so not concerned about UHD. Any PM greatly appreciated
If you won't ever be interested in UHD, go for a Pioneer external drive. Something like a BDR-XD07 or BDR-XD08. Very good drives but cannot currently be downgraded for UHD but work well for DVD and BD.
jordan1985
Any recommendations for uk.
UHD preferred, but on a budget, so looking at for non uhd aswell.
Preferably usb so I can move between server and pc easily.
Buy a Verbatim 43888. Also UHD compatible.jordan1985 wrote: ↑Mon Aug 26, 2024 2:41 pmAny recommendations for uk.
I ordered on Amazon Germany:
Verbatim Externer Slimline Bluray Writer Ultra HD 4k 80 Euro
Excellent Pioneer drive, works out of the box.
My location is Germany.Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-06-15
Highest AACS version: 36
Drive platform: RS8A10
Firmware version: 1.14
i can confirm that Verbatim 43888 works good just out of the box
AlbrechtDürer
I'm also looking for recommendations for a drive. I'm in Europe (D) and need an internal SATA Pioneer drive. Thanks for any input.
I am in the United States and am looking for a drive with UHD support. It can be internal 5.25 (adapted using a Vantec NexStar DX2) or external. I was originally looking at the LG WH16NS40, but am open to any other recommendations based on experience. Thank you!
I would recommend the pioneers i sell I would not even consider LG or Asus as long as pioneers are available with old fw.tylerrobb wrote: ↑Sun Sep 08, 2024 5:24 pmI am in the United States and am looking for a drive with UHD support. It can be internal 5.25 (adapted using a Vantec NexStar DX2) or external. I was originally looking at the LG WH16NS40, but am open to any other recommendations based on experience. Thank you!
See below
I just wanted to answer you that I finally managed got the Drive you recommended.
