hkdata.crabdance.com or hkdata.fairuse.org not found
Re: hkdata.crabdance.com or hkdata.fairuse.org not found
Post by Woodstock » Fri May 31, 2024 3:04 pm
I'm kind surprized this is still an issue after 5 months....
Five MONTHS? Look at the date of the first message of this thread... Five YEARS, so far.
The blocking of the key domain isn't tied just to MakeMKV, but it is tied to where the author is located. This forum gets away with being able to be resolved in DNS because it is separate. Originally, the keys were pulled from the makemkv.com domain, until they started to make this domain "go away" as a "piracy-supporting domain". The author separated the domain to keep the forum alive.
Crabdance and fairuse have endeavored to support "questionable" places for years, but a number of DNS-resolution companies have been complying with legal dictates to isolate those places. If your DNS provider is one of them, you cannot resolve ANY host in *.crabdance.com or *.fairuse.org, as well as dozens (hundreds?) of others. That's why you need to either (a) use a DNS provider that isn't blocking them, or (b) bypass DNS look-up using an entry in your hosts file. Sometimes, you need to use a VPN connection to bypass some providers, WHEN YOU NEED TO DO A LOOKUP.
That last part is the key - you do not have to enable a connection to the key server to run MakeMKV, unless you need a key for a new disk. If you don't rip 4K disks, who cares?
Right now, both hkdata.crabdance.com and hkdata.fairuse.org are off-line, but the statement posted in this message does still work. The host is there, but the DNS entry isn't.
Post by mike admin » Mon Jun 17, 2024 8:45 pm
Fixed, should work now. As a side note, these resources do not require a valid DNS entry to be operational.
HarryKrishner
Post by HarryKrishner » Mon Jul 01, 2024 3:56 am
mike admin wrote: Mon Jun 17, 2024 8:45 pm Fixed, should work now. As a side note, these resources do not require a valid DNS entry to be operational.
Do we still need VPN when trying to download keys? I'm still getting "Automatic HK downloading is disabled or failed." error when trying to do Super Mario Bros (1993) UHD viewtopic.php?f=12&t=33912.
Post by dcoke22 » Mon Jul 01, 2024 7:02 pm
HarryKrishner wrote: Mon Jul 01, 2024 3:56 am
It would appear that you do.
Post by MartyMcNuts » Sat Aug 10, 2024 3:38 am
Hey, does anyone know if there has been any recent key updates? My last update was August 1st. Haven't had any HK download messages at all.
Also, has anyone heard from Mike at all? He hasn't posted since June.
Post by dcoke22 » Tue Aug 20, 2024 2:15 pm
MartyMcNuts wrote: Sat Aug 10, 2024 3:38 am Hey, does anyone know if there has been any recent key updates? My last update was August 1st. Haven't had any HK download messages at all.
My MakeMKV downloaded new HK data today, but it has probably been a few weeks since it needed to try. In my _private_data.tar file, I assume the hashed keys are stored in the hkd_********.bin files. They seem to be named in a base16 way (0..f). The file with the largest name in mine is hkd_0000025f.bin.
Post by MartyMcNuts » Wed Aug 21, 2024 4:23 am
dcoke22 wrote: Tue Aug 20, 2024 2:15 pm
Yeah, I did get a new HK download a few days ago.
R1pp3r
Post by R1pp3r » Thu Nov 21, 2024 4:52 pm
h436d wrote: Fri May 31, 2024 2:32 pm Did you ever figure this out? I am in the exact same situation.
In my case it was a Network Issue.
IDS/IPS and Adblockers on my Firewall blocked the Requests.
Killersigge
Post by Killersigge » Sat Dec 14, 2024 11:46 am
Is there anyone that can confirm that a server is up and running with the SDF file and/or the HK with UHD-keys?
I have tried on two different computers at home and also a third at my work but I only get that the latest SDF is disabled or failed and also the HK downloading is disabled or failed when trying to open any new UHD disc.
Would be nice to know if there is a server running before I try putting in time to find a local sollution.
pcolmer
Post by pcolmer » Sat Dec 14, 2024 12:04 pm
I am able to resolve hkdata.crabdance.com, and I can point a browser at the address. However, the SSL certificate is either missing or invalid. Thankfully, http traffic seems to work but I don't know what path I need to provide in order to manually download what MakeMKV is trying - and failing - to download.
Other messages have referenced "svq/sdf.dat.gz" but that does not seem to be a complete file (gunzip complains it is a multi-part file).
Is there a manual solution to downloading the HK data?
pcolmer
Post by pcolmer » Sat Dec 14, 2024 12:31 pm
pcolmer wrote: Sat Dec 14, 2024 12:04 pm Is there a manual solution to downloading the HK data?
Downloading keydb.cfg has, at least for one of the discs I recently bought, solved my problem.
Just in case anyone else is stuck or having problems ...
peterkirkham
Post by peterkirkham » Sun Dec 15, 2024 2:02 am
I was having a problem accessing the server to download the latest HK data. Tried a number of suggested workarounds. Went to bed, tried again in the morning and all was OK. Sometimes a little patience might be all that is required :-)
