NEW Single Drive Flasher - available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
#436 Post by MartyMcNuts » Sun Jul 21, 2024 8:24 am
Joannebok wrote: Sun Jul 21, 2024 12:30 am Hi Marty, can you point me to a comparison for the drives you have in stock? I am thinking of getting one of your internal pioneer drives. I assume internal drives are more reliable?
Not sure what you mean by a comparison??
Joannebok
#437 Post by Joannebok » Sun Jul 21, 2024 12:36 pm
I mean to ask what is the difference between each of the drives?
#438 Post by MartyMcNuts » Sun Jul 21, 2024 9:59 pm
Joannebok wrote: Sun Jul 21, 2024 12:36 pm I mean to ask what is the difference between each of the drives?
The higher the price, the better quality components and overall build quality.
If you want to know about speed, they all read UHD discs at 4x max.
Joannebok
#439 Post by Joannebok » Tue Jul 23, 2024 3:34 am
I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
#440 Post by MartyMcNuts » Wed Jul 24, 2024 12:42 am
Joannebok wrote: Tue Jul 23, 2024 3:34 am I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
No problem. Unfortunately there are currently no compatible external Pioneer drives available as they all come with un-downgradable firmware. There is the Verbatim 43888 which contains a Pioneer BDR-UD04 drive inside but that's it.
#441 Post by MartyMcNuts » Fri Jul 26, 2024 12:11 am
Stock levels updated in first post.
#442 Post by MartyMcNuts » Mon Jul 29, 2024 10:01 am
#443 Post by MartyMcNuts » Thu Aug 01, 2024 3:24 am
#444 Post by MartyMcNuts » Sun Aug 04, 2024 8:19 am
#445 Post by MartyMcNuts » Thu Aug 08, 2024 2:26 am
#446 Post by MartyMcNuts » Tue Aug 13, 2024 1:11 am
#447 Post by MartyMcNuts » Wed Aug 14, 2024 3:54 am
#448 Post by MartyMcNuts » Thu Aug 15, 2024 8:02 am
#449 Post by MartyMcNuts » Sat Aug 17, 2024 7:41 am
#450 Post by MartyMcNuts » Tue Aug 20, 2024 12:40 am
