For anyone who is receiving SCSI medium errors:
I was using an ASUS 16D1HT, which provided me with perfect (albeit loud) ripping for all of my discs other than these. But no amount of isopropyl alcohol with a microfiber cloth would even allow a single disc to be read. I finally broke down and bought a Pioneer BDR-2213, and it's reading all of the discs perfectly with no errors.
If you search through these comments, nobody is complaining about a Pioneer drive having an issue with reading - just decrypting. I don't think the ASUS drives can properly read these discs for whatever reason.
Star Wars 4Ks
TheRealAlexDC
Re: Star Wars 4Ks
I'm having a bit of an issue trying to rip my Skywalker Saga.
I successfully ripped the 4k disks for A New Hope, Return of the Jedi, The Last Jedi, and The Rise of Skywalker.
I'm trying Attack of the Clones, but I get Illegal Request Copy Protection errors. Any ideas on how to make it work?
This is my drive info on MakeMKV:
and this is the error I get when trying to read the disk:
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 72
Firmware version: 1.03
Disc Information
Label: ATTACK OF THE CLONES
Timestamp: 2020-02-03 13:11:26
Protection: AACS2.0/C v72
Data capacity: 57.31 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.18.1 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MOAP41G1552d" opened in OS access mode.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:/IOBDServices/BEDDBAD7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/BEDDBAD7'
Saved AACS dump file as /***/***/Library/MakeMKV/MKB20_v72_Star_Wars-_Attack_of_the_Clones_6673.tgz
Re: Star Wars 4Ks
What happens if you power cycle the drive and restart your Mac?TheRealAlexDC wrote: Sun Sep 07, 2025 1:39 pm
BigART
Re: Star Wars 4Ks
Brand new to ripping, Are the alien talking subtitles part of the video or do I need to figure out which english subtitles I need select?
Re: Star Wars 4Ks
Actually, alien languages are not always translated in Star Wars (or Star Trek, but that's a separate issue). Many times, it is only the mood of the speech that is important. If the meaning IS important, it will be displayed whether you have general subtitles turned on or not (it's a "forced subtitle").
BigART
Re: Star Wars 4Ks
So as long as I check all english subtitles as well as (english) forced it should work? I ask because a youtube video I was viewing shown using another program to see which english forced subtitles to select and re-rip it to only have only that. Another video shown just to select all english subtitles with their respective forced subtitles and you're guaranteed to have all the forced subtitles. Subtitles as I understand it don't take up hardly any space unless you're compressing the video. I do not plan on compressing at all. I have over 1000 movies I want to back up and I want to use best practices. I just purchased an 8 bay Ugreen Nas with 8 28Tb HDD's. I'm currently waiting on those drives and also hoping m.2's go on sale for cyber Monday so I can run those in a Raid1 and use Jellyfin on it.Woodstock wrote: Wed Nov 26, 2025 4:36 pm Actually, alien languages are not always translated in Star Wars (or Star Trek, but that's a separate issue). Many times, it is only the mood of the speech that is important. If the meaning IS important, it will be displayed whether you have general subtitles turned on or not (it's a "forced subtitle").
Re: Star Wars 4Ks
When I last ripped Star Wars disks, I selected "all subtitles" to rip, because they weren't flagged correctly on my disks. I then would play the tracks, and select subtitle tracks to find the ones I wanted. Generally, I select "forced" and "everything" in English, but tag the forced track as first/default. I actually use mkvtoolnix to do the flagging, AFTER running the track through handbrake to make it smaller.
Some of the SW disks have 7 or 8 subtitle tracks on them, for a number of languages. Some even have subtitles with commentary.
Ripping "everything" makes it easy enough to later chose what I want, without having to go through the ripping process. For me, that's the only part that involves spinning the disk.
Unfortunately, I get to go through that all again, for a couple of thousand disks, because someone stole my media servers. At least I got the original disks out before the thief struck...
