Output File Size
Hairlesswookiee
Output File Size
Post by Hairlesswookiee » Thu Jul 28, 2011 5:58 pm
Hello, I hope this is the right place so please move it if it isn't. After reading a how-to I'm going to try backing up some movies this weekend. Is it possible to set a size limit for the .MKV file? The how-to I read suggests using Handbrake for size compression, but I was planning on keeping the .MKV file and putting it on my Netgear Stora. Any help/suggestions would be appreciated.
Smithcraft
Re: Output File Size
Post by Smithcraft » Thu Jul 28, 2011 8:28 pm
Handbrake and MakeMKV do two different things.
Handbrake transcodes the content, typically making the files smaller.
MakeMKV copies the content, and does not alter it (other than making the changes you select).
SC
azimut2000
Post by azimut2000 » Sun Aug 21, 2011 9:23 am
Smithcraft wrote:Handbrake and MakeMKV do two different things.
SC
Will it be possible that one day MakeMKV will transcode the content (like compress in H264 or other format that we will choice) ???
It will be great !!!!
MakeMKV on Win7 X64
MakeMKV on Mandriva x64
Use It !!!!!
Smithcraft
Post by Smithcraft » Mon Aug 22, 2011 2:59 am
I hope not.
SC
reebok
Post by reebok » Thu Aug 25, 2011 3:08 pm
I second that. It took me a long time to find a bluray ripper that DIDN'T re-encode. the entire reason I want to rip bluray is for the high quality on my projector, not so I can spend hours transcoding and downgrading the quality.
crowfax
Post by crowfax » Thu Aug 25, 2011 5:19 pm
reebok wrote:It took me a long time to find a bluray ripper that DIDN'T re-encode.
+1
Introducing this sort of functionality will introduce needless complexity into MakeMKV.
SWRogue
Post by SWRogue » Thu Sep 15, 2011 8:37 am
Id like to see the Option of re-encoding the MKVs made with MakeMKV Im happy with smaller files of the Movies I have I think others would like that as an option as well.
If it is left as an Option there should be no problem with doing a Straight RIP or an re-encoded RIP.
crowfax
Post by crowfax » Thu Sep 15, 2011 4:04 pm
SWRogue wrote:Id like to see the Option of re-encoding the MKVs made with MakeMKV Im happy with smaller files of the Movies I have I think others would like that as an option as well.
You should use handbrake or one of the 10's of other tools out there for re-encoding then.
AQ_OC
Post by AQ_OC » Tue Sep 27, 2011 3:29 pm
I like having a ripper that maintains 1:1 filesize. I can easily use handbrake if a decide I need more compression and longer wait times. MakeMKV is perfect along the path it is going.
