Recommendation for best (most reliable and versatile) LibreDrive for 2024?
gck303
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Post by gck303 »
I am after an internal slimline sata drive in the UK.
Would rather a slimline internal drive as it avoids me replacing my computer or adding another usb box to my desk!
Thanks, G
Lynellia
Post by Lynellia »
I have the same interest/question.
I am in the US
An external would be preferred but I can be flexible if an internal 5 1/4" SATA would be better
Lynellia wrote: Wed Aug 21, 2024 7:36 pm I have the same interest/question.
I am in the US
in the usa i have 5.25 pioneers with old fw see below
Beedum
Post by Beedum »
What's the best external drive to get for ripping dvd and bluray? On a bit of a budget so not concerned about UHD. Any PM greatly appreciated
Beedum wrote: Fri Aug 23, 2024 6:25 pm Hi,
If you won't ever be interested in UHD, go for a Pioneer external drive. Something like a BDR-XD07 or BDR-XD08. Very good drives but cannot currently be downgraded for UHD but work well for DVD and BD.
jordan1985
Post by jordan1985 »
Any recommendations for uk.
UHD preferred, but on a budget, so looking at for non uhd aswell.
Preferably usb so I can move between server and pc easily.
jordan1985 wrote: Mon Aug 26, 2024 2:41 pm Any recommendations for uk.
Buy a Verbatim 43888. Also UHD compatible.
spezi
Post by spezi »
I ordered on Amazon Germany:
Verbatim Externer Slimline Bluray Writer Ultra HD 4k 80 Euro
Excellent Pioneer drive, works out of the box.
Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-06-15
Highest AACS version: 36
Drive platform: RS8A10
Firmware version: 1.14
My location is Germany.
gonti
Post by gonti »
i can confirm that Verbatim 43888 works good just out of the box :)
AlbrechtDürer
Post by AlbrechtDürer »
I'm also looking for recommendations for a drive. I'm in Europe (D) and need an internal SATA Pioneer drive. Thanks for any input.
tylerrobb
Post by tylerrobb »
I am in the United States and am looking for a drive with UHD support. It can be internal 5.25 (adapted using a Vantec NexStar DX2) or external. I was originally looking at the LG WH16NS40, but am open to any other recommendations based on experience. Thank you!
tylerrobb wrote: Sun Sep 08, 2024 5:24 pm I am in the United States and am looking for a drive with UHD support. It can be internal 5.25 (adapted using a Vantec NexStar DX2) or external. I was originally looking at the LG WH16NS40, but am open to any other recommendations based on experience. Thank you!
I would recommend the pioneers i sell I would not even consider LG or Asus as long as pioneers are available with old fw.
See below
Okona
Post by Okona »
Coopervid wrote: Wed Jul 03, 2024 8:02 am PM sent.
Got it, however I cannot answer you via PM.
Okona wrote: Tue Sep 10, 2024 6:39 pm
You need more posts. Only then you are allowed to PM.
Okona
Post by Okona »
Coopervid wrote: Tue Sep 10, 2024 7:44 pm
I just wanted to answer you that I finally managed got the Drive you recommended.
