Multichannel audio instead of dts/dolby
inlandchris
Post by inlandchris »
I am using the latest version and all my rips have multichannel audio instead of my favorite DTS. Can someone give me a link where I can fix this? I tried to find subjects on this forum related to my problem but cannot find it.
Best
Craig
:D
Re: Multichannel audio instead of dts/dolby
MakeMKV just rips what's on the disc. If the disc has Dolby Digital and not DTS, then there's nothing MakeMKV can do.
MediaInfo is a handy utility for seeing details about your .mkv files.
inlandchris
It seems to be only 4K disc that has 7.1 dolby or dts, it just comes out as multichannel.
:D
inlandchris wrote:
Tue Aug 20, 2024 7:53 am
It seems to only be 4K disc and it doesn’t matter if the 4k disc has dolby or dts, it just comes out as multichannel.
I'm not sure what you mean by 'multichannel'.
Can you use mediainfo and post what it says about the .mkv file in question?
inlandchris
I did not know about mediainfo.exe, thank you.
Attached is an html export but this forum couldn't take it so I copied it and saved it as a txt file.
You can see the "MLP" and also Dolby TrueHD which that should have been the one instead of MLP; thats for surround sound 7.1
Let me know what you think
Output:
Unique ID : 332031487346101411194263870401733884168 (0xF9CAF03AB73105C6490EF93493BE7908)
Complete name : E:\Movies\Movie 2023\The Equalizer 3.mkv
Format : Matroska
Format version : Version 2
File size : 43.5 GiB
Duration : 1 h 48 min
Overall bit rate mode : Variable
Overall bit rate : 57.1 Mb/s
Frame rate : 23.976 FPS
Movie name : The Equalizer 3
Encoded date : 2023-12-10 15:12:07 UTC
Writing application : MakeMKV v1.17.5 win(x64-release)
Writing library : libmakemkv v1.17.5 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 51.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.261
Stream size : 39.5 GiB (91%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1057 cd/m2
Maximum Frame-Average Light Level : 333 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 827 kb/s
Maximum bit rate : 6 783 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.91 GiB (7%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 499 MiB (1%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Dialog Normalization : -31 dB
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Audio #3
ID in the original source medium : 4353 (0x1101)
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
Text #1
ID in the original source medium : 4768 (0x12A0)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 47 min
Bit rate : 27.4 kb/s
Frame rate : 0.384 FPS
Count of elements : 2465
Stream size : 21.0 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
ID in the original source medium : 4769 (0x12A1)
Format : PGS
Duration : 1 h 40 min
Bit rate : 19.9 kb/s
Frame rate : 0.293 FPS
Count of elements : 1764
Stream size : 14.3 MiB (0%)
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Duration : 1 h 29 min
Bit rate : 7 608 b/s
Frame rate : 0.118 FPS
Count of elements : 632
Stream size : 4.87 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:10:51.525 : en:Chapter 02
00:14:26.574 : en:Chapter 03
00:21:57.607 : en:Chapter 04
00:27:03.622 : en:Chapter 05
00:32:57.433 : en:Chapter 06
00:39:29.575 : en:Chapter 07
00:44:53.107 : en:Chapter 08
00:49:06.526 : en:Chapter 09
00:55:47.010 : en:Chapter 10
01:01:03.951 : en:Chapter 11
01:08:49.583 : en:Chapter 12
01:15:17.971 : en:Chapter 13
01:23:02.394 : en:Chapter 14
01:31:05.084 : en:Chapter 15
01:38:41.707 : en:Chapter 16
:D
You can copy and paste text and add it to your post. Right now we don't see anything.
So you got everything in the file. Your problem is how you play the file.
Pretty much all of my 4K rips that have Dolby TrueHD audio look the same in MediaInfo.
As you probably know, the lossless audio formats, Dolby TrueHD and DTS-HD MA, have what is referred to as a 'lossy core' inside them. It is constructed in such a way that old receivers and players that can only decode regular Dolby Digital AC-3 or DTS will play the lossy core and ignore the rest. Newer equipment that can decode the lossless format will play the lossless stuff and ignore the lossy core. Lots of software playback systems can get a little confused by this, so MakeMKV will, by default, make a copy of the lossy core as a separate track in the resulting .mkv file.
My example here is Dolby TrueHD that also happens to have Dolby Atmos and the lossy core of Dolby Digital AC-3 as track 2.
MLP or Meridian Lossless Packing refers to the compression algorithm used to compress the Dolby TrueHD stream.
Audio #1
Duration                                 : 1 h 55 min
Bit rate                                 : 4 406 kb/s
Maximum bit rate                         : 7 623 kb/s
Stream size                              : 3.54 GiB (5%)
Audio #2
Codec ID                                 : A_AC3
Stream size                              : 527 MiB (1%)
As Coopervid has suggested, it might be the case that your playback setup isn't dealing with the Dolby TrueHD audio correctly.
inlandchris
Okay, thank you for the advice. I have an oppo 4k player (203) and I changed the audio playback setup to output bitstream instead of auto. I still get MLP as an audio choice but when it goes into my onkyo RZ810, it now reads as Dolby TrueHD 7.1! Thank you.
My Oppo still cannot choose Dolby and only gives me MLP (for 7.1) and the others (5.1) is Dolby 5.1
I really like my Oppo because it can handle SACD music and I have an 18TB hard drive attached to the USB 3.0 for my 4k movies, thanks to this forum and MakeMkv software.
So, it’s no big deal when my choices are MLP and dolby 5.1. I am only concerned if I can do something about it. The MLP translate to Dolby TrueHD in my onkyo which is fine.
Thanks to all for help
:D
