I'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
The Dark Knight Trilogy
& Zack Snyder's Justice Library with no issue
Re: Aquaman And The Lost Kingdom (4K)
Drive is under powered. System keeps "losing" it when it spins at max. speed.rlentz2024 wrote: ↑Sat Aug 17, 2024 7:58 pmI'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
Be sure to use both USB plugs, or a USB C port if available.
Try different USB port(s)... back panel preferred.
Try a POWERED USB hub.
Clean the disc before trying again.rlentz2024 wrote: ↑Sat Aug 17, 2024 7:58 pmI'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
I don't think its the power because both USB plugs in and I had no problem doing Dune Part Oned00zah wrote: ↑Sat Aug 17, 2024 8:14 pmDrive is under powered. System keeps "losing" it when it spins at max. speed.rlentz2024 wrote: ↑Sat Aug 17, 2024 7:58 pmI'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
Dune Part Two
& Zack Snyder's Justice Library (League)...
I cleaned the disc a few times already, but I will try it again.MartyMcNuts wrote: ↑Sat Aug 17, 2024 10:35 pmClean the disc before trying again.rlentz2024 wrote: ↑Sat Aug 17, 2024 7:58 pmI'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
I just purchased a POWERED USB hub and Micro USB to USB C cable to see if that helps... This way I can rule it all out.d00zah wrote: ↑Sat Aug 17, 2024 8:14 pmDrive is under powered. System keeps "losing" it when it spins at max. speed.rlentz2024 wrote: ↑Sat Aug 17, 2024 7:58 pmI'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
I tried both a POWERED USB Hub and Micro to USB C and neither will allow me to do the movie... Same issue.
If other discs still work fine, then it's probably a bad disc.rlentz2024 wrote: ↑Mon Aug 19, 2024 11:09 pmI tried both a POWERED USB Hub and Micro to USB C and neither will allow me to do the movie... Same issue.
Either replace the disc and try again or get yourself a Pioneer drive and see if that can rip it.
