Aquaman And The Lost Kingdom
rlentz2024
Re: Aquaman And The Lost Kingdom (4K)
Post by rlentz2024 »
I'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
The Dark Knight Trilogy
& Zack Snyder's Justice Library with no issue
Post by d00zah »
rlentz2024 wrote: Sat Aug 17, 2024 7:58 pm I'm having problems with ripping Aquaman And The Lost Kingdom and I keep getting errors like: Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM0421363418 and I don't what is going on. I cleaned the disc and I'm using MakeMKV 1.17.7 on a LG BP60NB10 (Svc Code: NB12). Any help would be great.
I was able to rip
Dune Part One
Dune Part Two
Drive is under powered. System keeps "losing" it when it spins at max. speed.
Be sure to use both USB plugs, or a USB C port if available.
Try different USB port(s)... back panel preferred.
Try a POWERED USB hub.
I was able to rip
Dune Part One
Dune Part Two
Clean the disc before trying again.
rlentz2024
d00zah wrote: Sat Aug 17, 2024 8:14 pm
I was able to rip
Dune Part One
Dune Part Two
I don't think its the power because both USB plugs in and I had no problem doing Dune Part One
Dune Part Two
& Zack Snyder's Justice Library (League)...
rlentz2024
MartyMcNuts wrote: Sat Aug 17, 2024 10:35 pm
I was able to rip
Dune Part One
Dune Part Two
I cleaned the disc a few times already, but I will try it again.
rlentz2024
I was able to rip
Dune Part One
Dune Part Two
I just purchased a POWERED USB hub and Micro USB to USB C cable to see if that helps... This way I can rule it all out.
rlentz2024
I tried both a POWERED USB Hub and Micro to USB C and neither will allow me to do the movie... Same issue.
rlentz2024 wrote: Mon Aug 19, 2024 11:09 pm I tried both a POWERED USB Hub and Micro to USB C and neither will allow me to do the movie... Same issue.
If other discs still work fine, then it's probably a bad disc.
Either replace the disc and try again or get yourself a Pioneer drive and see if that can rip it.
