Unable to backup DVD-Audio discs
neurocrash
Post by neurocrash »
I am trying to backup some DVD-Audio discs that result in a backup failure with MakeMKV. The discs are DVD-Audio, apparently copy-protected using CPPM (DVDAUDIO.MKB and DVDAUDIO.BUP are present in the AUDIO_TS directory).
Is there any additional log or disc image that I can provide?
MakeMKV v1.17.7 win(x64-release) started
Backing up disc into folder "D:/Ripping Temp/ONCE_UPON_A_TIME.iso"
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Backup failed
OS device name: G:
Current profile: DVD-ROM
Product: BD-RE BE14NU40
Revision: 1.01
Serial number: [redacted]
Firmware date: 2114-06-25 14:41
Bus encryption flags: 1F
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Disc Information
Label: ONCE_UPON_A_TIME
Timestamp: 2005-02-10 16:39:46
Protection: CSS/CPPM
Data capacity: 6.2 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
