Pioneer BDR-XD07B UHD Flash
TheMalayanTiger
#1 Post by TheMalayanTiger » Thu Aug 15, 2024 9:20 pm
I recently read that BDR-XD07B could be flashed to enable UHD ripping and managed to find one which was manufactured April 2022.
Based on MakeMKV's printout, I should be able to reflash it but I don't know how or if its possible...
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: [redacted]
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8D30
Firmware version: 1.03
Any advice would be much appreciated.
Re: Pioneer BDR-XD07B UHD Flash
#2 Post by Billycar11 » Thu Aug 15, 2024 10:02 pm
email me that makemkv drive info see below
BBDogDvd
#3 Post by BBDogDvd » Fri Aug 16, 2024 12:14 pm
I am having a similar issue. I thought I could you the drive directly without needing to update the firmware. My Firmware is from 2018. Is this not true?
My drive works with non-UHD, but can not decrypt UHD disks.
Do I need to change the firmware to get UHD disks to work?
Thank you
OS device name: /dev/rdisk3
Product: BD-RW BDR-XD07U
Revision: 1.01
Serial number:
Firmware date: 2018-12-03
Highest AACS version: 72
Drive platform: RS8D31
Firmware version: 1.01/ID05
#4 Post by Billycar11 » Fri Aug 16, 2024 4:06 pm
BBDogDvd wrote: Fri Aug 16, 2024 12:14 pm I am having a similar issue. I thought I could you the drive directly without needing to update the firmware. My Firmware is from 2018. Is this not true?
Thank you
Revision: 1.01
Serial number:
Should work as is
