Are backups worth it in the long run?
Absolve6780
Post by Absolve6780 » Thu Aug 15, 2024 2:51 pm
I have been using MakeMKV for a while now. I was wondering if people who have been using MakeMKV for more than a couple years have ever went back to a backup copy for something, and if so, how frequently. My thought process is that, if I try to follow the 3-2-1 backup rule, then those raw MKV files should stand the test of time. I should also be able to play the raw MKV on Jellyfin or Plex in the future.
My question in its entirety is: How often do you use a backup copy for something? Is it worth taking 1/2 of your digital storage space for this?
My partially related second question is: How often do you "flash" the backup to a Bluray/DVD? If so, what are you using to do it?
Re: Are backups worth it in the long run?
Post by Woodstock » Thu Aug 15, 2024 6:12 pm
The definitive answer is, "It Depends!"
If you want to play the BD as distributed, yes, it is.
If (like me) the only reason you bought the DVD/BD was to get the main program on it (don't care about "extras"), no. Especially if you're going to use something like handbrake to shrink the files. Anime takes up only 10-20% of the space that it was on a BD when compressed. Movies take 40-60%. Toss out the extras, and the space savings is huge... and I still have the BDs in storage if I need them for some reason.
Some people sell off the original disks once they rip them, saving only the rip. I cannot say what they decide in the space game.
Absolve6780
Post by Absolve6780 » Fri Aug 16, 2024 2:05 pm
Thanks for sharing! I think I might just keep the disks themselves as the backups and keep only the mkv as the digital portion. I can get 1/2 of the space back I have now. I'm worried about burning out the GPU/CPU so I don't use handbrake at all. I might look into it in the future.
Post by Woodstock » Fri Aug 16, 2024 2:36 pm
With proper cooling and no overclocking, the CPU/GPU should last for a very, very long time. Mine are over a decade old, and I've run them for encodes for weeks at a time (the various Star Trek disks alone took almost two weeks to encode). But, if you aren't crunched for space, encoding isn't a big issue.
Post by dcoke22 » Sat Aug 17, 2024 4:48 pm
I keep my raw rips as well as the transcoded files I end up with.
The smaller files are handy to put on portable devices and use in general. I've probably burned many 1000s of hours of CPU time making encoded files. As Woodstock has suggested, with proper cooling your computer should last a long, long time. I too have had encoding sessions that lasted longer than a week.
The hardest part of turning your collection of movies into more useful digital files is the ripping process. It is the slowest part at least in terms of one's personal time investment. (It might take longer to transcode the rip into a more portable file, but most of that time doesn't require any human input.) When you think about your digital files over a longer time line, say a decade, the type of file you choose to transcode into today might not be the kind of file that'll make the most sense in the future. Having the raw rips means you can easily transcode again from the highest quality source file.
I've only been working on my digital movie collection for a few years. I've transcoded every one of my movies at least once. But in truth I'm on version 5 or 6 of how I encode movies. I've started re-encoding my collection more than once to bring my encodes up to my current standard.
Storing many TBs of rips comes with a cost, but hard drives keep getting bigger and the $/TB keeps coming down. In my case, I store my rips on an OpenZFS pool with a single disk of redundancy (and UPS battery backup). I don't have a backup, but I do have all of my source discs sitting on my shelf. This is how I've balanced the cost of keeping my rips with the convenience of having the rips accessible. In my view, movie rips aren't the same thing as irreplaceable family photos & videos.
PegasusPilot
Post by PegasusPilot » Wed Aug 21, 2024 6:08 am
I completely agree with everything Woodstock and dcoke22 said. I’ve never had my hardware fail from the thousands of hours spent ripping/muxing/encoding over the years.
I’d also like to add that I started off as an idiot when it comes to archiving data and manipulating my digital media; I used to think lossy compression was just as good as original mastered sources and have had to rebuild substantial parts of my music library with better quality versions as I realized my file qualities were crap. A single, high-quality backup (following 3-2-1) would have made changing formats from mp3->aac->mk4 or flv->mp4->mkv through re-encoding easier and faster.
Live and learn, I suppose.
Cheers friend(s)
christopher2222
Post by christopher2222 » Wed Mar 26, 2025 11:17 pm
Here's my 2 cents. Recently I started using the backup and this is the reason. If you want to get an MKV from a backup it's easy, just reload the index.bdmv from the bdmv folder and have makemkv make the mkv. So currently there are issues moving an mkv onto bluray using tsmuxer because it can't understand the new atmos trueHD and some of the 7.1 audio encodings. SO if you have a bit of ocd and you want the same audio from the mkv onto a bluray then your going to be a little upset when it ignores the 7.1 audio. Fortunately there's a bit of a work around using eac3to - just use that command line on the mkv to .. not alter, but make it so you have a 7.1 audio file for tsmuxer can understand. Then you re-add the audio file back in using tsmuxer beside the original mkv to mix it back into a bluray readable folder to burn to a disc using imgburn. Still that ocd might be burning because it won't be exactly the original.
With a backup on your drive, it's just straight to Imgburn to disc and no fiddling around, and you've got your backup disc ready for your home theatre system, complete with menus.
The other thing is that it's so hard to make two mkv videos on a dual layer bluray work due to differing formats of audio maybe video I'm not sure but as far as I know, it's not a simple task. It's almost better just to have the menus and a full working bluray to fill up the disc anyways so the wasted space is used up by something you could watch to kill time anyways.
Now if you don't care about matching the original audio tracks 7.1 - that is 5.1 is all you need for the future then just make the mkv, but then if you loose the disc or it gets damaged you won't have the extras
In conclusion I would say yes, the backups are definitely worth it.
drxenos
Post by drxenos » Thu Mar 27, 2025 10:07 pm
Absolve6780 wrote: Fri Aug 16, 2024 2:05 pm Thanks for sharing! I think I might just keep the disks themselves as the backups and keep only the mkv as the digital portion. I can get 1/2 of the space back I have now. I'm worried about burning out the GPU/CPU so I don't use handbrake at all. I might look into it in the future.
My transcoding rig is well over 10 yrs. old. It's been running HandBrake all that time, sometimes weeks at a time. A properly cooled system shouldn't have anything to worry about.
In fact, there was one time my CPU cooler's fan died late at night. It sat there trying to transcode all night long with no ill effects. Modern processors are that good at throttling themselves.
Corleone
Post by Corleone » Mon May 19, 2025 12:40 am
It depends on a few factors and on your objective. In my case, I rip almost everything to ISO images in my NAS, then watch them in a Kodi PC. These days I watch mostly the movie extras, actually - I rarely have time to watch a 2h+ movie (but I'm still hoping that will change soon). And I have a second copy in offline hard disks that I synchronize with the NAS every now and then.
I would really hate to spend the time to rip them all over again. I had to do that once when I only had DVDs, much fewer than now, and it was painful.
The only time I thought I would burn a copy from the backup was when I bought Rush's R30 DVD set and found out the layer break in the main concert was in the middle of a song. I was going to try to re-author the disk with the layer break in a less inconvenient spot, but never got around to it.
As for the CPU... I might be wrong, but I would expect your optical drives should die before the CPU.
molisa
Post by molisa » Thu May 29, 2025 7:20 am
Absolve6780 wrote: Thu Aug 15, 2024 2:51 pm Hi,
https://forum.cobiansoft.com/viewtopic.php?t=2672 traffic rally
Backups are definitely worth it long-term. I've used my MakeMKV backups several times for various reasons. Flashing to Blu-ray/DVD is useful for preservation; I use ImgBurn for that.
drxenos
Post by drxenos » Thu May 29, 2025 5:26 pm
https://www.techspot.com/news/107068-hu ... -away.html
I would say, yes, backups are definitely worth it.
annakylie
Post by annakylie » Thu Sep 25, 2025 4:30 am
You're doing the right thing by thinking about the 3-2-1 backup rule; it's an effective method for keeping data safe. On a few occasions, either because of hardware failures or because I deleted anything by accident, I've had to depend on backup copies.
SirYodaJedi
Post by SirYodaJedi » Thu Sep 25, 2025 6:32 pm
I'd keep full disc backups of all my discs if I could, but I "only" have 4 TB. I keep unprocessed MKVs of a few works that I think meaningfully suffer from being decompressed (mainly anime; I can get live action stuff looking great down to 8-10% the size, but 2D animated stuff suffers even at 40%), but otherwise I just keep it in whatever quality I'd accept dealing with if my discs burned in a house fire.
I also don't bother recompressing DVDs a lot of the time because they're already as low as I'm willing to go (and for 480i interlaced stuff, it sometimes gets bigger when I try to reencode it).
Jack Thauer
Post by Jack Thauer » Sun Sep 28, 2025 12:08 am
Definitely worth it. Have almost all my blu rays backed up via makemkv and now trying to work on 4ks. Currently stressed about finding drives for UHD backup.
Post by Woodstock » Sun Sep 28, 2025 12:43 am
Figure I should add one tiny data point that I just recently experienced... THEFT. Any backup that uses hardware that can be stolen is flawed. Last week, my video servers were stolen; fortunately, I had stored the original disks off-site two months prior. I have a LOT of stuffing of disks to do once I purchase new hardware, but, I didn't lose any video disks.
If you're going to do the backup route, make sure it is kept off-site, "just in case".
