oropher
Post
by oropher » Thu Aug 15, 2024 12:41 pm
Coopervid wrote: Thu Aug 15, 2024 8:39 am
oropher wrote: Wed Aug 14, 2024 8:31 pm
Hi Coopervid,
Wondering if you could help me on the flash. My version is 1.0 but I am unable to find 1.01 firmware online.
OS device name: /dev/rdisk5
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: [redacted]
Firmware date: 2019-01-07
Highest AACS version: 81
Firmware version: ID69
PM sent.
Thank you for the swift reply.
Do you have a version for Mac? I see that the executable is in exe.
Post
by Coopervid » Thu Aug 15, 2024 1:11 pm
No. You need a Windows PC or an emulation.
oropher
Post
by oropher » Thu Aug 15, 2024 7:48 pm
Coopervid wrote: Thu Aug 15, 2024 1:11 pm
Thanks for the help.
I am able to successfully flash to a compatible firmware by trying it on a Windows device
jhnkane
Post
by jhnkane » Fri Aug 16, 2024 8:18 pm
hi , i own the BDR-XS07S and am interested in the firmware pack!
i found a "Drive Utility" from pioneer :
https://pioneer.jp/device_e/product-e/i ... 01r_e.html
im also interested in any best-practices/suggestions for this drive. i wonder if its possible to playback discs on an android tv (usb connection with Sony TV).
thank you.
BDR-XS07S and DP-UB9000P1K
Post
by Coopervid » Fri Aug 16, 2024 10:11 pm
jhnkane wrote: Fri Aug 16, 2024 8:18 pm
thank you.
You need to post your Makemkv info. For the other stuff you need to start a separate post. Sounds you are completely new to this.
AND DONT UPDATE YOUR PIONEER FIRMWARE from their site.
jhnkane
Post
by jhnkane » Sat Aug 17, 2024 12:07 am
Coopervid wrote: Fri Aug 16, 2024 10:11 pm
thank you.
sorry , my mistake:
OS device name: E:
Revision: 1.01
Serial number: BEDLxxxxxxUC
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 61
i understand your point regarding firmware. i was more-so interested in the drive utility. thank you for clarifying.
Post
by Coopervid » Sat Aug 17, 2024 10:09 am
jhnkane wrote: Sat Aug 17, 2024 12:07 am
thank you.
sorry , my mistake:
OS device name: E:
Revision: 1.01
PM sent.
jhnkane
Post
by jhnkane » Mon Aug 19, 2024 1:09 am
Coopervid wrote: Sat Aug 17, 2024 10:09 am
PM sent.
thank you. no pressure but lmk your thoughts on the following:
1) is there a reason that your share isnt publicly available in the thread? if it is agaisnt the forum rules , we're OK to break them via pm?
1b) and my first post here so "Sounds you are completely new to this." is fair
2) maybe nothing to respond to and i sincerely appreciate the time spent writing the original application..however , it would be nice to re-write the process with flashrom and bin or something other than an exe. idk im planning to look into a different process.
takecare.
Post
by Coopervid » Mon Aug 19, 2024 9:02 am
jhnkane wrote: Mon Aug 19, 2024 1:09 am
PM sent.
takecare.
1) Yes. But I will not elaborate why.
2) ???? You have no idea regarding the history and the methods needed to make this work. So don't leave any unqualified comments. The skunk works of this goes back decades.
CompletelyLawless
Post
by CompletelyLawless » Mon Aug 19, 2024 5:08 pm
Coopervid,
I also cannot PM (despite being registered for a year). I have a Pioneer drive I would like to flash. Can you contact me please?
OS device name: E:
Revision: 1.03
Serial number: XXXXXXXXX
Firmware date: 2023-01-06
Highest AACS version: 77
Post
by Coopervid » Mon Aug 19, 2024 6:19 pm
CompletelyLawless wrote: Mon Aug 19, 2024 5:08 pm
Coopervid,
OS device name: E:
Revision: 1.03
Your firmware is too new and can't be flashed. Sorry!
Post
by d00zah » Mon Aug 19, 2024 6:21 pm
Coopervid,
OS device name: E:
Revision: 1.03
You need 3 posts before the PM restriction is lifted IIRC, not time lurking.
If you updated your FW since acquiring the drive, you shot yourself in the foot...
CompletelyLawless
Post
by CompletelyLawless » Mon Aug 19, 2024 6:30 pm
Coopervid wrote: Mon Aug 19, 2024 6:19 pm
Coopervid,
OS device name: E:
Revision: 1.03
There is no way to downgrade to 1.01 if I locate a copy of that firmware?
jhnkane
Post
by jhnkane » Mon Aug 19, 2024 6:33 pm
Coopervid wrote: Mon Aug 19, 2024 9:02 am
lol you have a weird attitude. you're distributing someone else's program.
you don't know me. im familiar with in-system programming.
Coopervid , thanks for sharing the mega but you need to relax.
Post
by Coopervid » Mon Aug 19, 2024 6:50 pm
jhnkane wrote: Mon Aug 19, 2024 6:33 pm
Sorry. You don't know jack about this program, its history and any other thing regarding it. You are just cocky. Why don't you program your own flasher if you think it's as easy as 1-2-3?
