Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
nargeolograc
#1 Post by nargeolograc » Wed Aug 14, 2024 3:19 am
So I have had this drive for a while and finally decided to do something with it. Doing a search on the forum has brought up a few posts with a matching Drive platform but all of them are either closed/marked as complete or were referring to sending PMs/emails so I figured it would smarter to just open a new thread instead of attaching to an existing thread that might now be being ignored.
There was some information regarding two or three different firmwares, but I couldn't really sus out which was the final choice in the posts regarding this drive platform. And I wanted to back up the stock firmware first but the SDFtool v1.3.5 doesn't seem to want to touch the drive because its not the MT1959 platform and the Asus flasher from the "New Option" post doesn't appear to give the option of backing up the existing firmware.
Below is the info showing in MakeMKV. Any suggestions or should I just not bother with this drive and replace it with something else?
OS device name: L:
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: ------------
Firmware date: 2017-01-15
Highest AACS version: 68
Drive platform: Pioneer RS8600
Firmware version: ID76
Re: Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
#2 Post by Coopervid » Thu Aug 15, 2024 8:46 am
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
nargeolograc
#3 Post by nargeolograc » Fri Aug 16, 2024 3:40 am
Thanks for sending along that info. It appears to have worked.
neotoma
#4 Post by neotoma » Wed Oct 30, 2024 2:40 pm
I am running into the same issue as the user as the OP. Any help would be appreciated!
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: [redacted]
Firmware date: 2018-01-15
Drive platform: RS8600
Firmware version: E102/ID76
robduggan
#5 Post by robduggan » Tue Apr 15, 2025 8:09 pm
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
Hi Coopervid, can you share the same information that you PM'ed to me as well? I have the same drive specs.
#6 Post by Coopervid » Tue Apr 15, 2025 9:06 pm
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
Post your owm Makemkv info.
Rugbyguy1
#7 Post by Rugbyguy1 » Wed Apr 23, 2025 3:18 am
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
I have the exact same drive. Did you get it flashed?
#8 Post by Billycar11 » Wed Apr 23, 2025 4:45 am
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
email me for the flasher see below
DarkFrost89
#9 Post by DarkFrost89 » Wed Apr 23, 2025 7:47 am
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
Hi Coopervid I New Buy BW-16D1X-U This Drive But I didnt flashed yet can you send me flasher tool and firmware please ?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
#10 Post by Coopervid » Wed Apr 23, 2025 1:36 pm
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
DarkFrost89
#11 Post by DarkFrost89 » Fri Apr 25, 2025 7:09 am
PM sent.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
Thank You So Much its Worked :)
dedero
#12 Post by dedero » Sat Apr 26, 2025 6:06 pm
I'm having the same issue but with a BW-16D1H-U, would be possible to flash?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: ...
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E114/ID71
#13 Post by Coopervid » Sat Apr 26, 2025 9:38 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: ...
PM sent.
dedero
#14 Post by dedero » Sun Apr 27, 2025 11:43 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: ...
PM sent.
Thanks a lot! it worked perfect, however, after flashing it shows S11 instead of S11 V2 as mentioned, is that OK?. Thanks
#15 Post by Coopervid » Mon Apr 28, 2025 2:23 am
Yes. 8600 drives flash to S11 V1 and 8601 drives flash to S11 V2 but this doesnt matter for the end user. Just regarding the fitting firmware.
