Mastering display color primaries (bt2020 or P3), this information is present only in cmv4.0 Level 9.
FYI, I've added the info in the quick info(1) and DV plotter (6-3) (6-4) in the latest beta
Rororororo
Can bloc CMv4.0 actually be transferred to any FEL movies? I noticed that you added Super Mario Bros (2023) movie to the red list, and in the green list you removed the mention that block CMv4.0 can be moved to BD-FEL
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
Rororororo
Got it.
Have you somehow modified your furiosa RPU from GDrive? Mine isn't exactly the same after transferring L3L6L9. Yours has duplicate frames/scene cuts at the end and different L6/MAXCLL etc data.
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
When the bluray is MEL, I dont transfer the levels to the P7 RPU. I just make a regular P5 to P8 hybrid straight from the WEB-DL.
Rororororo
Damn, everytime I feel that I may be stoopid.
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
Looking at Bikeriders in the Green area. Don't understand why. It seems worse than the original grade on the UHD. I know you labeled it "MDP mismatch" but I don't see it being in green.
Hallo Reset how to install CORELEC properly on ugoos am6b+ any sources please ?RESET_9999 wrote: ↑Tue Aug 13, 2024 9:48 pmWhen the bluray is MEL, I dont transfer the levels to the P7 RPU. I just make a regular P5 to P8 hybrid straight from the WEB-DL.
what ? picture quality (grain details) doesn't matter when you do hybrid since you only take the DV metadata.Bikeriders in the Green area. Don't understand why. It seems worse than the original grade on the UHD.
What matters is the brightness and it is the same: https://slow.pics/c/3xklvXxC
But DV for a 150nits nits HDR grade is totally useless.
there are two different installation tutorials linked in my ''DV playback devices'' Excel sheet
Thank youRESET_9999 wrote: ↑Wed Aug 14, 2024 2:17 pmwhat ? picture quality (grain details) doesn't matter when you do hybrid since you only take the DV metadata.Bikeriders in the Green area. Don't understand why. It seems worse than the original grade on the UHD.
reset_9999 i saw your pacific rim video today. is that really the best HDR10 movie?
I don't know if it's the best but it certainly has crazy bright highlights shot after shot. the Average/Average peak is over 1000nits and real maxcll is over 7000nits.
It actually looks way too bright / clipped on my low brightness C2(800nits) but in DV it looks perfect.
the comparisons in DV: https://mega.nz/file/ZWFjEa5L#H43rblIjC ... t8fpyxugZA
and in HDR10: https://mega.nz/file/5P0mCZYD#JQZFs9Oze ... EhA6tsFU7g
Nice to hear. I thought pacific rim was only hdr10 originally on uhd disc? No dv metadata?RESET_9999 wrote: ↑Wed Aug 14, 2024 7:15 pmI don't know if it's the best but it certainly has crazy bright highlights shot after shot. the Average/Average peak is over 1000nits and real maxcll is over 7000nits.
DV from web or generated. Theres no point watching HDR10 anymore...
RESET_9999 wrote: ↑Wed Aug 14, 2024 7:58 pmDV from web or generated. Theres no point watching HDR10 anymore...
Do yo recommend hybrid releases? I thought it was best to take the original rip?
