Ultimate UHD Drives Flashing Guide Updated 2024
Backing up disc into folder "E:/Video/backup/The shaolin temple"
Downloading latest HK to C:\Users\123/.MakeMKV ...
Saved AACS dump file as C:\Users\123/.MakeMKV/MKB20_v77_The_shaolin_temple_0C5E.tgz
Backup failed
Backup failed
You need to find out why this is failing. It could be a DNS issue, depending on your internet provider.Automatic HK downloading is disabled or failed.
My drive is a Pioneer BDR-2212 (built in to computer). Can it work or be added to the list?
Thank you, kindly,
Dave
Thank you, kindly,
Dave
So, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Non-Pioneer drives listed in the 1st post remain generally available, although the more expensive Pioneers are considered more reliable. 'Local' sellers are still able to provide non-crippled Pioneer drives. Look for one in your region.MasterZoen wrote: ↑Mon Aug 12, 2024 7:26 pmSo, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Of course there is!MasterZoen wrote: ↑Mon Aug 12, 2024 7:26 pmSo, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Verbatim 43888 (contains a Pioneer BDR-UD04) - Official UHD drive, no flashing required.
LG BU40N - Official UHD drive, flashing required.
LG BP60NB10 - Official UHD drive, fashing required.
It's a shame that these are all slimline so would need to go in an enclosure to be mounted in my desktop.MartyMcNuts wrote: ↑Tue Aug 13, 2024 1:04 amOf course there is!MasterZoen wrote: ↑Mon Aug 12, 2024 7:26 pmSo, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
If you want to mount it in a desktop PC, look at the BU40N and check Amazon / eBay for a 9.5mm to 5.25" drive bay adapter thingy.Mr_Orange wrote: ↑Tue Aug 13, 2024 1:09 amIt's a shame that these are all slimline so would need to go in an enclosure to be mounted in my desktop.MartyMcNuts wrote: ↑Tue Aug 13, 2024 1:04 amOf course there is!MasterZoen wrote: ↑Mon Aug 12, 2024 7:26 pmSo, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
The LG WH16NS60 was the go to official UHD drive but LG stopped producing it. The Pioneer UHD Official internal drives (with older firmware) really are the way to go. Far superior to any other manufacturer. Check with a seller on this forum or in my signature.
Thank you. I'm OK for the moment, I have an LG BH16NS55 flashed to the WH16NS60 which is performing flawlessly. I was just thinking about getting a backup. There are still some shops selling the BH16HS55 locally so I might get one of those and cross flash it when I need to.MartyMcNuts wrote: ↑Tue Aug 13, 2024 1:16 amIf you want to mount it in a desktop PC, look at the BU40N and check Amazon / eBay for a 9.5mm to 5.25" drive bay adapter thingy.Mr_Orange wrote: ↑Tue Aug 13, 2024 1:09 amIt's a shame that these are all slimline so would need to go in an enclosure to be mounted in my desktop.MartyMcNuts wrote: ↑Tue Aug 13, 2024 1:04 am
Of course there is!
I guess I'll try for that Verbatim drive, then. I was really bummed because my old WH14NS40 drive just died as I've started to rip my discs now that I have the storage for them.MartyMcNuts wrote: ↑Tue Aug 13, 2024 1:04 amOf course there is!MasterZoen wrote: ↑Mon Aug 12, 2024 7:26 pmSo, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Hello, I dont get what I'm supposed to do from here, I have a Pioneer drive. The model is the BDR-XD08EMB-S.
What am I supposed to do now ? Where do I find the firmware ?
Post your MakeMKV drive info
Actually I tried to just use MakeMKV without changing the firmware, and it seems to work so far, with my DVDs and Blu Ray, I've had no issue with like 15 discs. Here are the infos :
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-XD08U
Révision : 1.02
Numéro de série : [redacted]
Date micrologiciel : 2022-12-27
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 66
Drive platform: Pioneer RS9331
Firmware version: ID05
Aucun disque
Yeah, no, that can't be downgraded for UHD readability as the firmware is too new. The firmware date must be prior to Dec 2022.AntoninHS wrote: ↑Thu Aug 15, 2024 11:37 pmActually I tried to just use MakeMKV without changing the firmware, and it seems to work so far, with my DVDs and Blu Ray, I've had no issue with like 15 discs. Here are the infos :
Fabricant : PIONEER
Révision : 1.02
Aucun disque
