BluRay does not get read (LOTR Fellowship of the Ring)
DrBagel
Post by DrBagel » Wed Aug 14, 2024 3:35 pm
Hi everyone
I have a strange problem with one of my BluRays, namely The Lord of the Rings: The Fellowship of the Ring extendet version special 2 (CD4)
In fact the BluRay works without a problem, but MakeMKV can only find two chapters on the disc. Both chapters are shorter than a minute, so defenitely not the real content.
The logs does not yield any helpfull information for me (no error or anything), so maybe someone here can help me.
Thank you for any help in advance.
The LOG:
Debug log started at Wed Aug 14 15:29:22 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file://C:\Users\user/MakeMKV_log.txt
Using 1048320KB for read cache.
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF  v098: ASUS_BW-16D1HT_3.10_211901041014_KLLNAHA2929
No  SDF v098: Msft_Virtual_DVD-ROM_1.0
No auto SDF v098: Msft_Virtual_DVD-ROM_1.0
DEBUG: Code 0 at eP4E'9IxPe4XXL<dp:29396253
DEBUG: Code 0 at :_D~hKrDX!l7kzzP:213136746
SDF id v098: Msft_Virtual_DVD-ROM_1.0
003007:0000 Direkter Zugriffsmodus wird verwendet
Launching F:\Programme\Programme (x86)\MakeMKV\mmgplsrv64.exe
DEBUG: Code 0 at C#v3ZeLtng**"0ionBl\:29396460
003038:0000 CELLs 2-2 wurden vom Titelende entfernt
003028:0000 Titel #1 wurde hinzugefügt (1 cell(s), 0:00:45)
003025:0000 Titel #16 hat eine Länge von 11 Sekunden und wurde übersprungen, da die minimale Titellänge 40 Sekunden beträgt
005011:0000 Die Aufgabe wurde erfolgreich abgeschlossen
Application exited at Wed Aug 14 15:33:16 2024
Re: BluRay does not get read (LOTR Fellowship of the Ring)
Post by dcoke22 » Wed Aug 21, 2024 4:21 am
Are you sure that's a blu-ray disc? The log sorta looks like MakeMKV thinks it is reading a DVD.
DrBagel
Post by DrBagel » Sun Aug 25, 2024 11:54 am
Well at least it is in the BluRay box of the special extendet version of the lord of the rings. After having a look again at ther disc itself you're right. It seems like its "only" a DVD.
But all other bonus discs (which are also DVDs) work fine, only this specific one has the problem.
I just dont understands, why it can not find/read titles 2 to 15 and only finds title 1 and 16.
