Aspect ratio wrong
Threefold5
Aspect ratio wrong
#1 Post by Threefold5 » Tue Aug 13, 2024 5:28 pm
Update
I was a bit silly and didn't bother to check the playback of the DVD itself, it turns out that the DVD itself has the wrong aspect ratio for this one episode, while using VLC at least. I figure this isn't an issue with MakeMKV and is in fact an issue with the DVD itself. I would still much appreciate any help on converting the display aspect ratio correctly to that HandBrake see it correctly like it does with the rest of the titles.
I am trying to save the titles of a show from a DVD using MakeMKV. I have three disks and eighteen titles in total. Unfortunately one title is saving with the wrong aspect ratio in comparison to all the others, it keeps saving with an aspect ration of 4:3, the rest are 16:9. While all of the titles have a resolution of 720x576, all but this one will play at 16:9 by default. I have tried changing the display width and height to 1024x576 using MKVToolNix GUI, which works for VLC, but once I open it in HandBrake it detects it as 4:3 still and HandBrake doesn't allow me to change the display resolution.
MediaInfo
Correct aspect ratio
General
Format version                           : Version 2
File size                                : 819 MiB
Duration                                 : 24 min 49 s
Overall bit rate                         : 4 612 kb/s
Frame rate                               : 25.000 FPS
Encoded date                             : 2024-08-12 23:25:18 UTC
Writing application                      : MakeMKV v1.17.7 win(x64-release)
Writing library                          : libmakemkv v1.17.7 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 224 (0xE0)
Format                                   : MPEG Video
Format profile                           : Main@Main
Format settings                          : CustomMatrix / BVOP
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : Variable
Format settings, picture structure       : Frame
Codec ID                                 : V_MPEG2
Codec ID/Info                            : MPEG 1 or 2 Video
Bit rate                                 : 4 212 kb/s
Maximum bit rate                         : 9 800 kb/s
Width                                    : 720 pixels
Height                                   : 576 pixels
Active width                             : 718 pixels
Active display aspect ratio              : 16:9
Standard                                 : PAL
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.406
Time code of first frame                 : 09:59:59:00
Time code source                         : Group of pictures header
Stream size                              : 748 MiB (91%)
Original source medium                   : DVD-Video
Audio #1
ID in the original source medium         : 189 (0xBD)128 (0x80)
Codec ID                                 : A_AC3
Duration                                 : 24 min 48 s
Bit rate                                 : 192 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Stream size                              : 34.1 MiB (4%)
Title                                    : Stereo
Dialog Normalization                     : -27 dB
compr                                    : -0.28 dB
dsurmod                                  : Not Dolby Surround encoded
dialnorm_Average                         : -27 dB
dialnorm_Minimum                         : -27 dB
dialnorm_Maximum                         : -27 dB
Audio #2
ID in the original source medium         : 189 (0xBD)129 (0x81)
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Title                                    : Stereo
compr                                    : -0.28 dB
Text
ID in the original source medium         : 189 (0xBD)32 (0x20)
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : Picture based subtitle format used on DVDs
Duration                                 : 24 min 18 s
Bit rate                                 : 11.4 kb/s
Frame rate                               : 0.364 FPS
Count of elements                        : 531
Stream size                              : 1.98 MiB (0%)
Menu
00:00:00.000                             : en:Chapter 01
00:05:17.080                             : en:Chapter 02
00:10:18.440                             : en:Chapter 03
00:16:48.200                             : en:Chapter 04
00:24:48.040                             : en:Chapter 05
Wrong aspect ratio
General
File size                                : 760 MiB
Duration                                 : 24 min 2 s
Overall bit rate                         : 4 418 kb/s
Encoded date                             : 2024-08-13 17:02:14 UTC
Video
Format                                   : MPEG Video
Codec ID                                 : V_MPEG2
Bit rate                                 : 4 210 kb/s
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 4:3
Active display aspect ratio              : 4:3
Standard                                 : PAL
Bit depth                                : 8 bits
Stream size                              : 724 MiB (95%)
Audio
Codec ID                                 : A_AC3
Duration                                 : 24 min 1 s
Bit rate                                 : 192 kb/s
Stream size                              : 33.0 MiB (4%)
Title                                    : Stereo
compr                                    : -0.28 dB
Text
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Duration                                 : 23 min 35 s
Bit rate                                 : 11.5 kb/s
Frame rate                               : 0.371 FPS
Count of elements                        : 525
Stream size                              : 1.94 MiB (0%)
Menu
00:04:43.600                             : en:Chapter 02
00:09:10.240                             : en:Chapter 03
00:15:17.840                             : en:Chapter 04
00:24:01.680                             : en:Chapter 05
MKVToolNix GUI aspect ratio
General
File size                                : 1.54 GiB
Overall bit rate                         : 8 875 kb/s
Encoded date                             : 2024-08-13 17:23:36 UTC
Writing application                      : mkvmerge v86.0 ('Winter') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1
Video #1
Format                                   : MPEG Video
Codec ID                                 : V_MPEG2
Width                                    : 720 pixels
Height                                   : 576 pixels
Original display aspect ratio            : 4:3
Standard                                 : PAL
Bit depth                                : 8 bits
Stream size                              : 724 MiB (46%)
Video #2
Format                                   : MPEG Video
Codec ID                                 : V_MPEG2
Width                                    : 720 pixels
Height                                   : 576 pixels
Active width                             : 719 pixels
Standard                                 : PAL
Bit depth                                : 8 bits
Stream size                              : 748 MiB (47%)
Audio #1
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Stream size                              : 33.0 MiB (2%)
Title                                    : Stereo
compr                                    : -0.28 dB
Audio #2
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Stream size                              : 34.1 MiB (2%)
Title                                    : Stereo
compr                                    : -0.28 dB
Audio #3
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Title                                    : Stereo
compr                                    : -0.28 dB
Text #1
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Text #2
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Menu #1
Menu #2
It is worth noting that when using MKVToolNix GUI to change the display resolution and height a row for original display aspect ratio is added to MediaInfo which displays the original 4:3, is this what HandBrake is picking up on?
I can provide the raw ISO file if the developer needs it for diagnosis if it comes to that.
segfaulted
Re: Aspect ratio wrong
#2 Post by segfaulted » Wed Aug 14, 2024 1:14 am
Even if handbrake detects the wrong display aspect ratio, you should be able to override it. Uncheck the Automatic box and manually fill in the correct width as "Display Size". The encoded video will retain the original 720x576 frame size.
