ryanb0517
Re: SDFtool Flasher
Post by ryanb0517 » Thu Aug 01, 2024 3:57 am
Thank you, I checked in MakeMKV and it showed the 1.03 WP50NB40 firmware,
then I followed your steps to crossflash and it showed the correct 1.00 BU40N in MakeMKV
I tried inserting The Martian in UHD and it loaded up perfectly.
Thanks again and I will be checking out more stuff on this forum about burning and making blu rays
-Ryan
MilesPNZ
Re: SDFtool Flasher
Post by MilesPNZ » Tue Aug 13, 2024 4:01 am
Hi all,
I'm trying to run the SDFtool Flasher but I'm getting an error.
I'm running Windows 11 and using a Buffalo BRUHD-PU3-BK.
The app does launch but shows no drives present.
Here is a link to a screenshot of the error >>> https://imgur.com/mPOyBaU
Error code below:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.5.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
Riku55
Re: SDFtool Flasher
Post by Riku55 » Tue Aug 13, 2024 6:19 pm
Just downloaded the flasher today and got the exact same error as @MilesPNZ but on Windows 10.
Re: SDFtool Flasher
Post by d00zah » Tue Aug 13, 2024 6:44 pm
Riku55 wrote: Tue Aug 13, 2024 6:19 pm Just downloaded the flasher today and got the exact same error as @MilesPNZ but on Windows 10.
Is MakeMKV installed? SDFtool Flasher is a front-end for MakeMKV's native command line tool.
Requirements:
  • Windows 10 64 bit version
  • MakeMKV v1.15.1 (or higher) installed
  • .NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
Riku55
Re: SDFtool Flasher
Post by Riku55 » Tue Aug 13, 2024 9:08 pm
Oooh, I see. Didn't when trying the first time. Installed MakeMKV later but didn't retest it. It's working now. Sorry for being just another user who didn't read the requirements :'D
MilesPNZ
Re: SDFtool Flasher
Post by MilesPNZ » Wed Aug 14, 2024 3:56 am
d00zah wrote: Tue Aug 13, 2024 6:44 pm
Requirements:
Thank you!
My COVID brain missed this bit!
MilesPNZ
Re: SDFtool Flasher
Post by MilesPNZ » Wed Aug 14, 2024 5:44 am
Hoping somebody can help me with another question.
I'm using my Buffalo BRUHD-PU3-BK but I'm not sure exactly what firmware to flash to it.
I flashed DE_Buffalo_BRUHD-PU3_BU12-MK.bin which was sucessful but it still doesn't seem able to get the MKV from my BluRay (I'm using my copy of The Martian).
It's just spitting out errors.
Re: SDFtool Flasher
Post by d00zah » Wed Aug 14, 2024 1:56 pm
MilesPNZ wrote: Wed Aug 14, 2024 5:44 am Hoping somebody can help me with another question.
It would help enormously if you could share (copy/paste) the log so we can review the errors.
Luthex
Re: SDFtool Flasher
Post by Luthex » Wed Aug 21, 2024 2:56 pm
Could i get the .bin file for Pioneer XD08U1? Thank you
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Aug 22, 2024 12:49 am
Luthex wrote: Wed Aug 21, 2024 2:56 pm Could i get the .bin file for Pioneer XD08U1? Thank you
There isn't one! Also, that drive isn't flashable nor downgradable.
citykid3165
Re: SDFtool Flasher
Post by citykid3165 » Thu Aug 22, 2024 10:54 am
segfaulted wrote: Thu Aug 01, 2024 2:43 am Use RECOVER mode. You'll point it to the current firmware file, which might be DE_LG_WP50NB40-NB50_1.03_MK.bin if UHD discs haven't worked in your drive. Then you can select the firmware that you want to flash, choose DE_LG_BU40N_1.00.bin
The drive's LED light should blink during the flashing process if you did it correctly. If it doesn't blink, the drive is ignoring the reflash.
Hi there.
I tried following these instructions and it didn't work for my LG BP50NB40 and it still doesn't read discs even though it says it's patched.
The drive tries to load the discs but fail and the firmware stays on version 1.03.
I did the following
- RECOVERY and flashed HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917
- WRITE and flashed DE_LG BU40N_1.00
Surely I'm missing something here? I'm getting really confused. If someone could point me towards a guide that would be really good if possible.
This is what the info on MakeMKV says with a UHD disc in:
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK05O4O85803
Highest AACS version: 65
Firmware version: 1.03
citykid3165
Re: SDFtool Flasher
Post by citykid3165 » Thu Aug 22, 2024 11:33 am
MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
Hi - I followed these exact instructions yet it still doesn't want to read my UHD discs.
Firmware went through properly on the software however the drive doesn't show an indicator light whilst doing so.
I've used the firmwares in your firmware pack and still no dice and it still shows at BP50NB40.
I'm unsure on what to do. Only difference is that one of the ports may be USB 2.0 but shouldn't matter at least I think...
This is what MakeMKV says in the info:
OS device name: F:
Revision: 1.03
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Aug 22, 2024 10:43 pm
citykid3165 wrote: Thu Aug 22, 2024 11:33 am
4. Click START
OS device name: F:
Revision: 1.03
You are still on BP50 firmware therefore you did not follow the instructions correctly.
Do it again from step 2. Read the title bar of each popup window.
segfaulted
Re: SDFtool Flasher
Post by segfaulted » Thu Aug 22, 2024 11:57 pm
citykid3165 wrote: Thu Aug 22, 2024 10:54 am I did the following
That doesn't sound right. You've already done one WRITE to get on 1.03-MK, so skip that function from now on. Do the cross-flash with RECOVER.
When you choose RECOVER, the tool will first ask for the current firmware file... choose BP50NB40 1.03-MK. Then you click the dropdown and choose the firmware you actually want to flash, BU40N 1.00 and start the flash. Don't click on WRITE.
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Aug 23, 2024 2:28 am
segfaulted wrote: Thu Aug 22, 2024 11:57 pm
Which is precisely what the instructions from step 2 are telling him to do. He's just not following them correctly.
