I am unable the rip Superman (the original movie) without getting a bunch of errors. The disc itself looks fine. Here's the debug log:
Debug log started at Tue Sep 13 00:38:46 2011 , written by MakeMKV v1.6.14 darwin(x86-release)
001005:0000 MakeMKV v1.6.14 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/timur/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHI" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQUEAAACATIwNjAxMyAyNTAwMDg0MDA=
DCE=yDSes5dqq3eZMH8ea+6gRPe/AghmA0BM62ElKLE3mjqSpgh5IzphpdZnFc1rGiJLXI3tTGkt1ya6kFZQhlWh9MLrqNokstvpwBx/5P/P1r/NeFiLX0T88kkcyUslnm+bAukqd7mtsCZuCFiVu+Lnvx36FS7jF9T5gw==
DISCID=DC147286136F3A726D3C871B3805E3D042E4459F
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00001.m2ts has length of 12 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003307:0000 File 00005.m2ts was added as title #1
003307:0000 File 00006.m2ts was added as title #2
003025:0000 Title #00007.m2ts has length of 561 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 31 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 74 seconds which is less than minimum title length of 900 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 160 seconds which is less than minimum title length of 900 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/timur/Movies/LOGICAL_VOLUME_ID
001003:0020 DEBUG: Code 1073741829 at Y9?7SI/E=]R=7,3d:29393953
001003:0020 DEBUG: Code 2 at ~n^PnlTYxtG(%Z(6:121268719
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '9419421696'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '9419489280'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '9419618304'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '16209014784'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '16209082368'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '23379179520'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '23379247104'
001003:0020 DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394298
001003:0020 DEBUG: Code 0 at >Y%Q"#4rYx6\gYa>K4$8:121261681
001003:0020 DEBUG: Code 0 at bt0(3+ZwGR.7zBTww2?#:29394183
001003:0020 DEBUG: Code 11415648 at bt0(3+ZwGR.7zBTww2?#:29393309
001003:0020 DEBUG: Code 0 at [>a{Yff]psdpCqBw_s<H[:213134377
005003:0000 Failed to save title 0 to file /Users/timur/Movies/LOGICAL_VOLUME_ID/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Sep 13 01:33:35 2011
SCSI error ripping Superman Blu-ray
crowfax
Re: SCSI error ripping Superman Blu-ray
That's a disc/drive error.002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '23379247104'
Return the disc for a new one.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
