BDR-XD07J-UHD UHD Firmware
h436d
Post by h436d »
Hey Guys,
I got a BDR-XD07J-UHD, but it can't seem to extract UHD discs it keeps getting scsi errors I think I may need a custom firmware.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.00
Serial number: RCDLXXXXXXJP [redacted XXXXXX]
Firmware date: 2017-10-30
Highest AACS version: 81
Drive platform: RS8D31
Firmware version: 1.00/ID69
I wondered if I need a custom firmware, or if perhaps upgrading to pioneer firmware 1.03 might work.
I managed to guess the firmware URL for V1.03 based on the one for V1.05.
https://pioneer.jp/device_e/product-e/i ... W105EU.exe
https://pioneer.jp/device_e/product-e/i ... W103EU.exe (changed 5 to 3)
But then based on another thread where his drive reported libradrive enabled but he still couldn't read UHD I thought perhaps I need a custom firmware, and upgrading to V1.03 might not help.
viewtopic.php?f=16&t=32945
The error is as follows
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
.... removed 760 lines of similar errors ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as /home/user/snap/makemkv/627/.MakeMKV/MKB20_v70_MARVEL_STUDIOS'_SHANG-CHI_-_ULTRA_HD_5717.tgz
Any help would be much appreciated!
Re: BDR-XD07J-UHD UHD Firmware
h436d wrote:
Tue Aug 13, 2024 12:38 am
Hey Guys,
Revision: 1.00
Saved AACS dump file as /home/peter/snap/makemkv/627/.MakeMKV/MKB20_v70_MARVEL_STUDIOS'_SHANG-CHI_-_ULTRA_HD_5717.tgz
Your firmware is fine and do not update it.
Ensure you have enabled internet access in MakeMKV's preferences. You also may have an issue where your computer is blocking access to the MakeMKV servers (in Russia).
h436d
Post by h436d »
MartyMcNuts wrote:
Tue Aug 13, 2024 1:01 am
Hey Guys,
Revision: 1.00
Thanks so much for your reply. I have internet access enabled in preferences, I have no way of knowing if someone might be blocking my communication with the servers because I don't know where they are. There are no errors in the logs about updating any files or anything. Is there anyway to force it to attempt to check for updates so I could look for errors in logs?
EDIT: I just looked at viewtopic.php?t=25670
It seems I have access to https://www.makemkv.com/svq/sdf.bin so that doesn't seem to be an issue.
There is a comment further down that says "If you're getting that error then it means 1) Your disc isn't supported with local db 2) There is a new HK but MakeMKV is failing to download it for whatever reason. "
So I guess since there are no errors downloading I probably have the most up to date files and perhaps the disc just isn't supported? Does that sound about right? Is there anyway to know if I have the latest files?
EDIT2: Referring to viewtopic.php?f=12&t=16883
It says you can specify a keydb.cfg file manually and put it in your MakeMKV data directory which I have now done.
However I followed the step to check if a key exists for your disc by looking for the SHA1 hash of the file Unit_Key_RO.inf from the disc, and I wasn't able to find one in my keydb.cfg.
73a886037381e1ff3d1a9b6d9fbe6f6dfdf0e343 Unit_Key_RO.inf
I can only assume the database that MakeMKV refers to for keys thinks it has a key as MakeMKV doesn't say "the volume key is unknown for this disc" but instead prints a ton of SCSI errors.
Is it possible that the SCSI errors are just not being caught properly and are really an indiciation that "the volume key is unknown for this disc"?
h436d wrote:
Tue Aug 13, 2024 3:01 am
Hey Guys,
Revision: 1.00
Can you test some other UHD discs? It may be that your Shang Chi disc isn't supported but that would be quite odd as it's been around for a couple of years, unless it's a new pressing perhaps. You can email in the generated dump file to svq@makemkv.com and wait a couple of weeks for the key to be added.
As I said, it'd be best if you can try several other UHD discs to rule out any server/download releated issues. If other UHD dics work ok, it's probably just that disc. If all other UHD discs do the same, then you may have other issues.
h436d
Post by h436d »
MartyMcNuts wrote:
Tue Aug 13, 2024 3:27 am
Thanks again for your kind reply. I put an edit on my last comment showing that the SHA1 hash of the file didn't appear to be in any keydb.cfg file I could find online.
However I also tried 3 other UHD dics and they all generated similar SCSI errors.
I find it very curious that it's generating SCSI errors instead of printing the "the volume key is unknown for this disc" error as described on viewtopic.php?f=12&t=16883
The only other possible lead I have is that when I start the program it shows some warning about "CAP_SYS_RAWIO" before the SCSI errors start.
MakeMKV v1.17.7 linux(x64-release) started
Failed to get full access to drive "PIONEER BD-RW BDR-XD07U". Make sure that you either have write access to device "/dev/sr0", are member of "cdrom" group or have CAP_SYS_RAWIO enabled.
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:1'
.... scsi errors ....
Looking online seemed to indicate this was not a cause for concern though as many users have this error and it seemed like MakeMKV no longer needed those permissions.
I Just wanted to also confirm I have no problem with regular BDROM discs with AACS, it is only these AACS2.0 UHD discs that fail for me.
The errors at the end are also a bit confusing, as it is my understanding that AACS host certficate revokation isn't an issue with libredrive anyways?
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:1'
Saved AACS dump file as /home/user/snap/makemkv/627/.MakeMKV/MKB20_v72_How_to_Train_Your_Dragon-_The_Hidden_World_A954.tgz
h436d wrote:
Tue Aug 13, 2024 3:58 am
How is the drive connected?
Can you try it on Windows 11 and see if you get the same errors.
segfaulted
Post by segfaulted »
Looks like you're using the Ubuntu snap build of MakeMKV.
This error here means you'll need to grant permissions for the app.
Open a terminal and run this command...
snap connect makemkv:optical-write
and see if that fixes it.
h436d
Post by h436d »
Thanks MartyMcNuts and segfaulted. The problem was solved thanks to both your help.
I just installed the apt version of MakeMKV in the end and that worked without issue.
Windows 11 also worked fine when I tested it just now.
Sorry I should have thought to try that sooner.
Thanks again for both your help!
