MasterZoen
Post by MasterZoen »
So, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Post by d00zah »
MasterZoen wrote: Mon Aug 12, 2024 7:26 pm So, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Non-Pioneer drives listed in the 1st post remain generally available, although the more expensive Pioneers are considered more reliable. 'Local' sellers are still able to provide non-crippled Pioneer drives. Look for one in your region.
Of course there is!
Verbatim 43888 (contains a Pioneer BDR-UD04) - Official UHD drive, no flashing required.
LG BU40N - Official UHD drive, flashing required.
LG BP60NB10 - Official UHD drive, fashing required.
Mr_Orange
Post by Mr_Orange »
MartyMcNuts wrote: Tue Aug 13, 2024 1:04 am
Of course there is!
It's a shame that these are all slimline so would need to go in an enclosure to be mounted in my desktop.
Mr_Orange wrote: Tue Aug 13, 2024 1:09 am
Of course there is!
If you want to mount it in a desktop PC, look at the BU40N and check Amazon / eBay for a 9.5mm to 5.25" drive bay adapter thingy.
The LG WH16NS60 was the go to official UHD drive but LG stopped producing it. The Pioneer UHD Official internal drives (with older firmware) really are the way to go. Far superior to any other manufacturer. Check with a seller on this forum or in my signature.
Mr_Orange
Post by Mr_Orange »
MartyMcNuts wrote: Tue Aug 13, 2024 1:16 am
Of course there is!
Thank you. I'm OK for the moment, I have an LG BH16NS55 flashed to the WH16NS60 which is performing flawlessly. I was just thinking about getting a backup. There are still some shops selling the BH16HS55 locally so I might get one of those and cross flash it when I need to.
MasterZoen
Of course there is!
I guess I'll try for that Verbatim drive, then. I was really bummed because my old WH14NS40 drive just died as I've started to rip my discs now that I have the storage for them.
AntoninHS
Post by AntoninHS »
Hello, I dont get what I'm supposed to do from here, I have a Pioneer drive. The model is the BDR-XD08EMB-S.
What am I supposed to do now ? Where do I find the firmware ?
davey021 wrote: Mon Aug 12, 2024 7:17 pm My drive is a Pioneer BDR-2212 (built in to computer). Can it work or be added to the list?
Thank you, kindly,
Dave
Post your Makemkv info of the drive.
AntoninHS wrote: Wed Aug 14, 2024 3:52 pm Hello, I dont get what I'm supposed to do from here, I have a Pioneer drive. The model is the BDR-XD08EMB-S.
Post your MakeMKV drive info
AntoninHS
Post by AntoninHS »
MartyMcNuts wrote: Wed Aug 14, 2024 10:14 pm
Actually I tried to just use MakeMKV without changing the firmware, and it seems to work so far, with my DVDs and Blu Ray, I've had no issue with like 15 discs. Here are the infos :
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-XD08U
Révision : 1.02
Numéro de série : [redacted]
Date micrologiciel : 2022-12-27
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 66
Drive platform: Pioneer RS9331
Firmware version: ID05
Aucun disque
AntoninHS wrote: Thu Aug 15, 2024 11:37 pm
Fabricant : PIONEER
Révision : 1.02
Aucun disque
Yeah, no, that can't be downgraded for UHD readability as the firmware is too new. The firmware date must be prior to Dec 2022.
Fabricant : PIONEER
Révision : 1.02
Aucun disque
flashing is only needed for 4K UHD blurays not dvd and regular bluray
AntoninHS
Post by AntoninHS »
Okay, thank you for all these infos, and for your time ! :)
spud_gun
Post by spud_gun »
Hi folks, I'm new to MakeMKV and I'm looking to backup some UHD movies I own to digital copies
I'm going to purchase a drive for this and looking to get one that doesn't require flashing
It seems the Verbatim 43888 is the best option for now based on the last few pages, can someone confirm if this is the case?
Will any drive of that model work or do I need to ensure they're manufactured before a certain date?
Also, my understanding is they're actually a Pioneer drive in an enclosure, but the latest Pioneer drives from the factory can't be flashed with older firmware and aren't useful
Maybe someone could clear this up for me?
