MasterZoen
#2386 Post by MasterZoen » Mon Aug 12, 2024 7:26 pm
So, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
#2387 Post by d00zah » Mon Aug 12, 2024 11:43 pm
MasterZoen wrote: Mon Aug 12, 2024 7:26 pm So, from what I'm reading here, by skipping through 20 pages at a time, is that there's basically no new drives that are UHD Official and work for ripping? Man, that's a bummer.
Non-Pioneer drives listed in the 1st post remain generally available, although the more expensive Pioneers are considered more reliable. 'Local' sellers are still able to provide non-crippled Pioneer drives. Look for one in your region.
#2388 Post by MartyMcNuts » Tue Aug 13, 2024 1:04 am
Of course there is!
Verbatim 43888 (contains a Pioneer BDR-UD04) - Official UHD drive, no flashing required.
LG BU40N - Official UHD drive, flashing required.
LG BP60NB10 - Official UHD drive, fashing required.
Mr_Orange
#2389 Post by Mr_Orange » Tue Aug 13, 2024 1:09 am
MartyMcNuts wrote: Tue Aug 13, 2024 1:04 am
Of course there is!
It's a shame that these are all slimline so would need to go in an enclosure to be mounted in my desktop.
#2390 Post by MartyMcNuts » Tue Aug 13, 2024 1:16 am
Mr_Orange wrote: Tue Aug 13, 2024 1:09 am
Of course there is!
If you want to mount it in a desktop PC, look at the BU40N and check Amazon / eBay for a 9.5mm to 5.25" drive bay adapter thingy.
The LG WH16NS60 was the go to official UHD drive but LG stopped producing it. The Pioneer UHD Official internal drives (with older firmware) really are the way to go. Far superior to any other manufacturer. Check with a seller on this forum or in my signature.
Mr_Orange
#2391 Post by Mr_Orange » Tue Aug 13, 2024 1:20 am
MartyMcNuts wrote: Tue Aug 13, 2024 1:16 am
Of course there is!
Thank you. I'm OK for the moment, I have an LG BH16NS55 flashed to the WH16NS60 which is performing flawlessly. I was just thinking about getting a backup. There are still some shops selling the BH16HS55 locally so I might get one of those and cross flash it when I need to.
MasterZoen
#2392 Post by MasterZoen » Wed Aug 14, 2024 2:28 pm
Of course there is!
I guess I'll try for that Verbatim drive, then. I was really bummed because my old WH14NS40 drive just died as I've started to rip my discs now that I have the storage for them.
AntoninHS
#2393 Post by AntoninHS » Wed Aug 14, 2024 3:52 pm
Hello, I dont get what I'm supposed to do from here, I have a Pioneer drive. The model is the BDR-XD08EMB-S.
What am I supposed to do now ? Where do I find the firmware ?
#2394 Post by Coopervid » Wed Aug 14, 2024 4:57 pm
davey021 wrote: Mon Aug 12, 2024 7:17 pm My drive is a Pioneer BDR-2212 (built in to computer). Can it work or be added to the list?
Thank you, kindly,
Dave
Post your Makemkv info of the drive.
#2395 Post by MartyMcNuts » Wed Aug 14, 2024 10:14 pm
AntoninHS wrote: Wed Aug 14, 2024 3:52 pm Hello, I dont get what I'm supposed to do from here, I have a Pioneer drive. The model is the BDR-XD08EMB-S.
Post your MakeMKV drive info
AntoninHS
#2396 Post by AntoninHS » Thu Aug 15, 2024 11:37 pm
MartyMcNuts wrote: Wed Aug 14, 2024 10:14 pm
Actually I tried to just use MakeMKV without changing the firmware, and it seems to work so far, with my DVDs and Blu Ray, I've had no issue with like 15 discs. Here are the infos :
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-XD08U
Révision : 1.02
Numéro de série : [redacted]
Date micrologiciel : 2022-12-27
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 66
Drive platform: Pioneer RS9331
Firmware version: ID05
Aucun disque
#2397 Post by MartyMcNuts » Fri Aug 16, 2024 4:36 am
AntoninHS wrote: Thu Aug 15, 2024 11:37 pm
Fabricant : PIONEER
Révision : 1.02
Aucun disque
Yeah, no, that can't be downgraded for UHD readability as the firmware is too new. The firmware date must be prior to Dec 2022.
#2398 Post by Billycar11 » Fri Aug 16, 2024 6:02 am
Fabricant : PIONEER
Révision : 1.02
Aucun disque
flashing is only needed for 4K UHD blurays not dvd and regular bluray
AntoninHS
#2399 Post by AntoninHS » Fri Aug 16, 2024 4:18 pm
Okay, thank you for all these infos, and for your time ! :)
spud_gun
#2400 Post by spud_gun » Sun Aug 18, 2024 6:45 pm
Hi folks, I'm new to MakeMKV and I'm looking to backup some UHD movies I own to digital copies
I'm going to purchase a drive for this and looking to get one that doesn't require flashing
It seems the Verbatim 43888 is the best option for now based on the last few pages, can someone confirm if this is the case?
Will any drive of that model work or do I need to ensure they're manufactured before a certain date?
Also, my understanding is they're actually a Pioneer drive in an enclosure, but the latest Pioneer drives from the factory can't be flashed with older firmware and aren't useful
Maybe someone could clear this up for me?
