BD-RW BDR-UD04 Error Messages
SilverMaster
Post by SilverMaster »
Hi there,
I ordered a new UHD Drive yesterday on Amazon to rip 4K movies for private use.
Unfortunately I get Error Messages left and right, and I searched 30 minutes for an answer with no avail, maybe I am also just blind?
Anyhow, that is my new drive, straight out of the box:
Laufwerksinformation
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: [redacted]
Firmware-Datum: 2020-06-15
Highest AACS version: 66
Drive platform: RS8A10
Firmware version: 1.14
The error message I get is:
Fehler 'SCSI-Fehler - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-UD04 1.14 DFDL144039WL' bei Offset '1214464'
The offset number is the only variable that changes constantly.
If the drive is no good, I'll return it ASAP.
Thank you already for the help. :)
Re: BD-RW BDR-UD04 Error Messages
SilverMaster wrote: Mon Aug 12, 2024 4:05 pm Hi there,
Produzent: PIONEER
Revision: 1.14
At some point during reading a disc, the drive is not getting enough power. Don't use a USB hub unless it has it's own power supply (30w or greater). If using a desktop PC, use the USB ports on back of motherboard. Even better is to use USB-C if you are able to.
