Please add a "select/deselect all" box
michaelsurb
Post by michaelsurb » Sun Aug 11, 2024 2:14 pm
I have had a ton of my discs I am backing up with 20 or 30 boxes to uncheck when all I want to do is extract the main movie file. Can you please add a master checkbox at the top so I can deselect all choices at once? Then I can pick the ONE file I want to extract. Thanks!
Re: Please add a "select/deselect all" box
Post by Woodstock » Sun Aug 11, 2024 6:19 pm
And the right-click menu doesn't work for you? It already has "select/unselect all".
