hipsofjw
Post by hipsofjw »
Billycar11 wrote: Sun Jul 21, 2024 4:11 am
hipsofjw wrote: Sun Jul 21, 2024 3:24 am
MartyMcNuts wrote: Sun Jul 21, 2024 12:20 am
Show us the libredrive section below the section you posted above.
MakeMKV is not showing any LibreDrive information for this drive. I am on the latest version of MakeMKV.
Use the force flash commands
Here's what Powershell is giving me:
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d G: rawflash -i C:\Users\k\Downloads\DE_LG_BU40N_1.00.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Also tried it with "enc"
hipsofjw
Post by hipsofjw »
While waiting for my previous posts to be approved, I solved the issue by adding the -t mtk991 command. Already made my first rip. Thanks for the help!
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d G: rawflash -t mtk19xx -i C:\Users\k\Downloads\DE_LG_BU40N_1.03_MK.bin
Reading input file C:\Users\k\Downloads\DE_LG_BU40N_1.03_MK.bin
Current Drive ID: HL-DT-ST__BD-RE_BU40N_U100_211608311153_KFKGAJA1621
100% Operation finished
Done successfully
bjl1959
Post by bjl1959 »
New here but eager to learn. I get the following error code when trying to flash the LG drive: Ox82052603
I'm using an LG BD-RE WH14NS40, firmware 1.05, drive platform MT1959, the SVC code on the drive is NS50. the drive enclosure is an OWC Mercury Pro professional USB 3.0 model OWCMR3UKIT
I used the SDFtool flasher v1.3.5 and firmware pack DE_LG_WH14NS40-N S50_1.02.bin. if it matters I'm using a newer laptop with a core I9 processor running windows 11. Thanks
Post by d00zah »
bjl1959 wrote: Wed Jul 24, 2024 3:15 am New here but eager to learn. I get the following error code when trying to flash the LG drive: Ox82052603
Guide says:
WH14NS40 on any Firmware directly to > WH16NS60 1.02MK... NOT 'DE'
bjl1959
Post by bjl1959 »
Thanks. I'll download the firmware files again. FYI I downloaded the all you need firmware file and the DE files were all I seen after unzipping. I'll check it again using the link you provided. Thanks again.
bjl1959 wrote: Thu Jul 25, 2024 1:35 am Thanks. I'll download the firmware files again. FYI I downloaded the all you need firmware file and the DE files were all I seen after unzipping. I'll check it again using the link you provided. Thanks again.
Just make sure it is WH16NS60 1.02-MK. Doesn't matter if also DE.
niftydl
Post by niftydl »
Good day everyone,
Have a Archgon MD-8107S-U3-UHD drive with the drive info below. Do I need to flash the firmware for basic functionality? Any guidance greatly appreciated.
Product: BD-RE BU40N
Revision: 1.00
Firmware: 2116-12-20 15:28
Drive Platform: MT1959
Firmware version: 1.0
Thanks in advance.
Zadok666
Post by Zadok666 »
Hi everyone,
im pretty new to this stuff an I want to backup my UHD collection.
I'm in located in Germany, so I bought the Verbatim 43888 as it is available
in local stores.
When I trie to rip the "The Thing" UHD I get the following message
"AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
AACS Ausgabedatei als C:\Users\info/.MakeMKV/MKB20_v76_The_Thing_920D.tgz gesichert
Das Öffnen der Disk schlug fehl"
It's in German, sorry.
Here is the Information from MKVMaker
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: [redacted]
Firmware-Datum: 2020-06-15
Highest AACS version: 76
Drive platform: RS8A10
Firmware version: 1.14
Thanks in advance
bjl1959
Post by bjl1959 »
MartyMcNuts wrote: Thu Jul 25, 2024 6:43 am
downloaded the files again and used the WH16 version of the firmware. everything is now working. Thanks much for your help.
Zadok666 wrote: Tue Jul 30, 2024 2:28 pm Hi everyone,
in local stores.
Produzent: PIONEER
Revision: 1.14
Thanks in advance
I recently wrote a post about trying to rip a UHD and getting a dump file: https://forum.makemkv.com/forum/viewtopic.php?p=156849#p156849
The UHD FAQ is also a good resource.
manotroll
Post by manotroll »
Good evening, I have a uj240as but it has version 1.02. I bought it recently since the internal drives are expensive and my lg has been in use for a long time.
but all the places I found have broken links
The UJ240AS is never going to do UHD, as it was discontinued years before UHD was a thing. You are limited to DVD and (regular) BD reading, no matter what software version you have.
Hurricane
Post by Hurricane »
Backing up disc into folder "E:/Video/backup/The shaolin temple"
Downloading latest HK to C:\Users\123/.MakeMKV ...
Saved AACS dump file as C:\Users\123/.MakeMKV/MKB20_v77_The_shaolin_temple_0C5E.tgz
Backup failed
You need to find out why this is failing. It could be a DNS issue, depending on your internet provider.
davey021
Post by davey021 »
My drive is a Pioneer BDR-2212 (built in to computer). Can it work or be added to the list?
Thank you, kindly,
Dave
