Lost Season 3 Disc 1 Track 5
RealityRipple
Post by RealityRipple »
Every time I try to read the fifth track from the 1080p LOST Season 3 Disc 1, I get the following errors before read begins:
Saving 1 titles into directory D:/Videos/z_TMP
DEBUG: Code 1 at @!9QVZp^h6()wi~Ro<\<:213132491
DEBUG: Code 0 at %:>_$_fn:F/mi5m&^\*4:213130030
DEBUG: Code 0 at %:>_$_fn:F/mi5m&^\*4:29393309
DEBUG: Code 0 at WtF#"'***TGp@"|krRB"4:121265913
DEBUG: Code 0 at Ota^FTJgcqaz18ZL:u S:29401060
LIBMKV_TRACE: Exception: UpdateTrackInfo failed
Failed to save title 4 to file D:/Videos/z_TMP/title04.mkv
Occasionally the fifth track isn't listed at all.
MakeMKV_log.txt
Log File
(3.81 KiB) Downloaded 619 times
Re: Lost Season 3 Disc 1 Track 5
Post by mike admin »
Looks like a physical error. Please try making full disc backup per instructions at http://www.makemkv.com/faq/item/4/catid/4 and see if any hashcheck errors show up.
RealityRipple
Yep... Let's see...
Hash check failed for file /BDMV/STREAM/00115.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00115.m2ts : 100% corrupt, 0% correct, 100% checked.
Hash check failed for file /BDMV/STREAM/00103.m2ts at offset 922478592, file is corrupt.
Hash check failed for file /BDMV/STREAM/00103.m2ts at offset 922675200, file is corrupt.
Hash check failed for file /BDMV/STREAM/00103.m2ts at offset 940173312, file is corrupt.
Hash check failed for file /BDMV/STREAM/00103.m2ts at offset 2252335104, file is corrupt.
Hash check failed for file /BDMV/STREAM/00103.m2ts at offset 4667860992, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00103.m2ts.
Hash check for /BDMV/STREAM/00103.m2ts : 0.01% corrupt, 99.98% correct, 100% checked.
Hash check failed for file /BDMV/STREAM/00100.m2ts at offset 7381837824, file is corrupt.
Hash check failed for file /BDMV/STREAM/00100.m2ts at offset 7859202048, file is corrupt.
Hash check failed for file /BDMV/STREAM/00100.m2ts at offset 7859398656, file is corrupt.
Hash check failed for file /BDMV/STREAM/00100.m2ts at offset 7863134208, file is corrupt.
Hash check failed for file /BDMV/STREAM/00100.m2ts at offset 7866673152, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00100.m2ts.
Hash check for /BDMV/STREAM/00100.m2ts : 0.01% corrupt, 99.97% correct, 99.99% checked.
Hash check failed for file /BDMV/STREAM/00011.m2ts at offset 3317950464, file is corrupt.
Hash check failed for file /BDMV/STREAM/00011.m2ts at offset 6644361216, file is corrupt.
Hash check for /BDMV/STREAM/00011.m2ts : 0.00% corrupt, 99.99% correct, 99.99% checked.
Backup done but 4 files failed hash check
Romansh
Post by Romansh »
You could always try cleaning the disc.
RealityRipple
Romansh wrote:You could always try cleaning the disc.
If you have a more detailed or unique suggestion than every other cleaning method I've read, I'd love to know it. All my discs look perfectly fine to me, and I've cleaned them in every way I can think of, but most of them have issues of one sort or another. I've even tried cleaning the drive, but that didn't change anything, so I doubt it was dirty to begin with.
