ASUS BC-12D2HT , how to?
pixaren
Post by pixaren »
I just bought this drive for ripping my blu-rays.
I have no clue of how i should proceed with the firmware upgrade for adding 4K support.
Info
OS device name: E: Manufacturer: ASUS Product: BC-12D2HT
Revision: 3.11
Serial number: [redacted]
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Harware support: Yes
Firmware support: No
Firmware type: Original (patched version available) Firmware version: 3.11
DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware)
jinx100
Re: ASUS BC-12D2HT , how to?
Post by jinx100 »
See: viewtopic.php?t=30115
In the last post MartyMcNuts says use his tool: viewtopic.php?f=16&t=22896 and his "all-you-need-firmware" to flash it to DE_ASUS_BC-12D2HT_3.11_MK.bin
Edit:
According to the third post down at: viewtopic.php?f=16&t=22896&p=132630&hil ... HT#p132630
version 3.11 is already UHD capable.
One last link viewtopic.php?f=16&t=32758&p=145568&hil ... HT#p145568
