I have the same drive, can you help me please?Coopervid wrote: Wed Aug 07, 2024 4:26 pmPM sent.Rurido wrote: Wed Aug 07, 2024 2:57 pm Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Here's the info from MakeMKV:Any help is much appreciatedCode: Select all
Laufwerksinformation OS-Gerätename: \Device\CdRom0 Aktuelles Profil: BD-ROM Produzent: ASUS Produkt: SBW-06D2X-U Revision: 1.10 Serienummer: ~ Firmware-Datum: 2017-04-18 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.10/ID22 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Keine Disk eingelegt![]()
I_Has_Diabeetus
Re: Pioneer firmware update February 2023
You need to post your Makemkv info first. "same drive" is not sufficient.I_Has_Diabeetus wrote: Thu Aug 08, 2024 2:34 amI have the same drive, can you help me please?Coopervid wrote: Wed Aug 07, 2024 4:26 pmPM sent.Rurido wrote: Wed Aug 07, 2024 2:57 pm Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Hello! Is this still being worked on? I got a new BDR-XS07UHD today...oopsmike admin wrote: Sun Feb 26, 2023 4:22 pm As many of you have noticed, Pioneer released a mass firmware update for almost all drives. The firmware date is around December 2022 and release date is around February 2023. The sole purpose of this update is to disable LibreDrive and unofficial firmware flashing tools such as DVRtool.
This will eventually be dealt with. The ETA, whether drive flashing would be required, and the flashing process are yet unknown. We are working as fast as we can.
Please do not update the the drive firmware, unless you really need to.
I'm gonna keep it because I have more 1080p blurays than 4K ones. Looking forward to a fix for this. Much appreciated!
morphia128
Hello, I am new to all of this, unable to rip 4K-UHD, but successful with everything else, I understand the pioneer limitations. any advise is greatly appreciated, I am still within the return period but I can keep it if anything can be done.
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: ************
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
Revision: 1.02
Not possible. You got the new firmware that is not flashable anymore.morphia128 wrote: Tue Aug 13, 2024 7:13 pm Hello, I am new to all of this, unable to rip 4K-UHD, but successful with everything else, I understand the pioneer limitations. any advise is greatly appreciated, I am still within the return period but I can keep it if anything can be done.
Revision: 1.02
beansnrice
I just grabbed a Verbatim 43890, thinking it would support UHD drives (I'm replacing an LG drive that is slowing starting to create more and more errors, where it used to work flawlessly), and it isn't reading them today.
Was I wrong about the UHD support? I can return it, so I'm fine grabbing another.
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
That has a BDR-UD03 blu-ray drive in it. Only the Verbatim 43888 has a BDR-UD04 UHD drive inside.beansnrice wrote: Tue Aug 13, 2024 11:08 pm I just grabbed a Verbatim 43890, thinking it would support UHD drives (I'm replacing an LG drive that is slowing starting to create more and more errors, where it used to work flawlessly), and it isn't reading them today.
Revision: 1.14
I have a "fix" if you are interested.beansnrice wrote: Tue Aug 13, 2024 11:08 pm I just grabbed a Verbatim 43890, thinking it would support UHD drives (I'm replacing an LG drive that is slowing starting to create more and more errors, where it used to work flawlessly), and it isn't reading them today.
Revision: 1.14
beansnrice
Sure. DM me?Coopervid wrote: Wed Aug 14, 2024 4:59 pmI have a "fix" if you are interested.beansnrice wrote: Tue Aug 13, 2024 11:08 pm I just grabbed a Verbatim 43890, thinking it would support UHD drives (I'm replacing an LG drive that is slowing starting to create more and more errors, where it used to work flawlessly), and it isn't reading them today.
Revision: 1.14
Done.beansnrice wrote: Wed Aug 14, 2024 5:03 pmSure. DM me?Coopervid wrote: Wed Aug 14, 2024 4:59 pmI have a "fix" if you are interested.beansnrice wrote: Tue Aug 13, 2024 11:08 pm I just grabbed a Verbatim 43890, thinking it would support UHD drives (I'm replacing an LG drive that is slowing starting to create more and more errors, where it used to work flawlessly), and it isn't reading them today.
I have one of the Verbatim 43890 drives and would love to be able to allow it to read 4K UHD discs. Drive info as follows:
Revision: 1.14
Serial number: BADL473729WL
Highest AACS version: 63
Hope you can help!
Best regards
Ian
Revision: 1.14
Hope you can help!
Best regards
Ian
Email me for a autoflaher for that see belowdtsfan2k wrote: Thu Aug 15, 2024 1:58 pm Hi,
Revision: 1.14
Hope you can help!
Best regards
Ian
Am I able to access UHD with this drive? If so would love some direction or help. Much appreciated.
Revision: 1.14
Highest AACS version: 68
Revision: 1.14
Yes email me for an automated flasher see belownobojo01 wrote: Sat Aug 17, 2024 11:39 am Am I able to access UHD with this drive? If so would love some direction or help. Much appreciated.
Revision: 1.14
I have and you were of the greatest help! Thank you so much for all the help. Appreciate it so muchBillycar11 wrote: Sat Aug 17, 2024 3:06 pmYes email me for an automated flasher see belownobojo01 wrote: Sat Aug 17, 2024 11:39 am Am I able to access UHD with this drive? If so would love some direction or help. Much appreciated.
Revision: 1.14
Serial number: [na]
