Hey, all! I went ahead and bought a BP60NB10, flashed it with
HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
and started my first rip. It would only rip up to a maximum of 2.3x. I never saw it go any higher than that. I tried another disc and it read one stream at 2x and the next stream it started reading at only 0.8x...
I'm not really too sure what to do here... I tried restarting my computer, plugging the drive back in, tried different ports.... And yes I am using the Y cable that it comes with plugged into 2 ports for power and data. I did save the firmware from the drive before I flashed it.
BP60NB10 giving me very slow rip speed. 2x, 0.8x
Re: BP60NB10 giving me very slow rip speed. 2x, 0.8x
Did you try cleaning the discs? Do that before trying to rip again.Darkl0ud wrote: ↑Wed Aug 07, 2024 11:28 pmHey, all! I went ahead and bought a BP60NB10, flashed it with
Hey there Marty!
Thanks for the reply. I think it may have something to do with the discs themselves. I bought 2 blurays today, tried those two, and those were the two I made complaints about in this post. I then found out we had some other blurays already (I thought these were the only blurays we had, i am starting my bluray journey now!) and tried one of them and the rip starts off slower, but speeds up as it continues, peaking at nearly 6x. I will try those other discs after cleaning them after I am done with this rip.
Would you say this is all normal behaviour? Coincidentally, the two other discs I tried to rip that I complained about were both discs from season sets of a TV show. Are reading those more difficult?
I also ordered a new drive from Amazon, thinking my drive could be bad... I will flash that one when it gets here to compare.
Thanks so much for the help!
I wanted to also say, it took 21 minutes total for the rip to reach the 6x speed I mentioned. It is nearly the whole length of the rip for it to reach that speed. Is that normal? Not complaining, I am fine with this speed, just making sure it is indeed expected behavior.
segfaulted
It will depend on various factors like disc quality and file sizes, but your experience isn't unusual.Darkl0ud wrote: ↑Thu Aug 08, 2024 2:52 amI wanted to also say, it took 21 minutes total for the rip to reach the 6x speed I mentioned. It is nearly the whole length of the rip for it to reach that speed. Is that normal? Not complaining, I am fine with this speed, just making sure it is indeed expected behavior.
I have an LG BP50NB40 which should perform similarly to a BP60NB10. With several bluray (regular and 4K) discs I've tried, some can reach 6x within 2 minutes of starting a rip, while others take a whole 20 minutes to peak at 6x like yours. Either way, my drive's speed usually hangs around 4-5x for most of the rip.
Purely anecdotal from my end, so make what you will with this info.
