Marty or anyone else please help...MakeMKV not working with LG WH16NS40?
iredmc
Re: Marty or anyone else please help...MakeMKV not working with LG WH16NS40?
Yes I know, so I tried that, but the flasher doesn’t work. Just stays at 0% forever. I found a couple different ones that guides and people on here say *should* work, but none of them do.
How is the drive attacked. Internal - SATA? External - USB? Some SATA > USB adapters/enclosures have problems passing commands to the drive.iredmc wrote: Sat Jul 27, 2024 8:06 pm Yes I know, so I tried that, but the flasher doesn’t work. Just stays at 0% forever. I found a couple different ones that guides and people on here say *should* work, but none of them do.
iredmc
d00zah wrote: Sat Jul 27, 2024 8:28 pmHow is the drive attacked. Internal - SATA? External - USB? Some SATA > USB adapters/enclosures have problems passing commands to the drive.iredmc wrote: Sat Jul 27, 2024 8:06 pm Yes I know, so I tried that, but the flasher doesn’t work. Just stays at 0% forever. I found a couple different ones that guides and people on here say *should* work, but none of them do.
First I tried USB3, but I realized this might cripple it a bit for obvious reasons, so I connected it directly to a PC and a Mac through SATA - not at the same time, obviously.
Just to cover bases, assuming Windows, you've met the requirements?iredmc wrote: Sun Jul 28, 2024 12:04 am First I tried USB3, but I realized this might cripple it a bit for obvious reasons, so I connected it directly to a PC and a Mac through SATA - not at the same time, obviously.
- Windows 10 64 bit version
- MakeMKV v1.15.1 (or higher) installed
- .NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
On the left-hand panel, the following are checked?
- MT1959 Platform
- Encrypted Firmware (v/1.05 is encrypted)
On the right-hand pane, 'WRITE Firmware' is checked?
On a mac, using cli, 'enc' must be included in the command line.
iredmc
Not sure what an MT1959 platform means, if that means I need an SGX, well I tried it on a 4th gen Intel machine too and that did the same thing.d00zah wrote: Sun Jul 28, 2024 12:20 amJust to cover bases, assuming Windows, you've met the requirements?iredmc wrote: Sun Jul 28, 2024 12:04 am First I tried USB3, but I realized this might cripple it a bit for obvious reasons, so I connected it directly to a PC and a Mac through SATA - not at the same time, obviously.
- MT1959 Platform
I wasn’t even aware I could patch on a Mac, the softwares I have only run on Windows.
Yea, write firmware is checked. Also I tested read firmware, and when it worked at all it gave me a 74KB file which I don’t think is correct.
I’m assuming the app wouldn’t even start if I didn’t meet the .NET requirements, but yes I have that version and many others installed.
I updated MakeMKV a week ago or so before starting this stuff since it wouldn’t even let me use it anymore.
And yes, Windows 10 64 bit.
Ok I just looked up what MT1959 is, and I don’t know what that has to do with my drive or my machines.
How was the drive attached when you got this info? Based on it:
You can flash from the cli on a mac per instructions in the 1st post of the guide.
the 'SDFtool Flasher' (a front-end for the native MakeMKV cli tool) needs to detect/report that in order to correctly flash the drive.iredmc wrote: Fri Jul 26, 2024 9:16 pm ...
OS device name: G:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: [redacted]
Harware support: Yes
Firmware support: No
Firmware version: 1.05
iredmc
Straight through SATA in a Windows 10 PC.
iredmc
I have the flasher, the problem is it doesn’t work, as I think I stated before, that’s the problem.
isamu
iredmc wrote: Sun Aug 04, 2024 7:45 pm I have the flasher, the problem is it doesn’t work, as I think I stated before, that’s the problem.
This is gonna be a potentially dumb and obvious question but, before you're attempting to run the flasher, you made sure your disc drive is empty and fully closed, yes?
Marcus1626
Hi everyone, same problem here...
I have a newly purchased LG WH16NS40... less than a week ago...
OS device name: E:
Revision: 1.05
Highest AACS version: 64
MakeMKV is on in the background
I ran the " SDFtool Flasher v1.3.5", selected the right BD-RE, obtained a green check at both MT1959 and Encripted software, selected the right file.bin and obtained (after some work - after I hit start):
"Command produced error code 0x82052603"
please help!
OS device name: E:
Revision: 1.05
please help!
Marcus1626
Disregard everyone!
I figured it out!
Thanks all!
I figured it out!
Thanks all!
Try flashing the correct firmware: WH16NS60 1.02-MKMarcus1626 wrote: Wed Aug 07, 2024 7:58 pm Hi everyone, same problem here...
OS device name: E:
Revision: 1.05
please help!
iredmc
Of course. It wouldn’t try to flash at all if it wasn’t. This is still a problem, to be clear, but we are returning the drive since it’s basically useless to us with not being able to rip 4K blurays.isamu wrote: Sun Aug 04, 2024 11:18 pmiredmc wrote: Sun Aug 04, 2024 7:45 pm I have the flasher, the problem is it doesn’t work, as I think I stated before, that’s the problem.
