kazuma
#10216 Post by kazuma » Wed Aug 07, 2024 2:05 pm
Which movies are cmv 4.0?
deadchip12
#10217 Post by deadchip12 » Wed Aug 07, 2024 3:29 pm
A user from CoreELEC forum just posted this:
TLDR: CMv4.0 bug
Hey all - quick question.
I just received my AM6B + yesterday with the n firmware installed from the factory.
I installed the CoreELEC-Amlogic-ng.arm-21.1-Omega_nightly_20240804-Generic.img.gz without incident, utilizing dual boot, and was able to install the updated plexmod, etc etc.
All appears to be well. Everything appears to play just fine, dolby vision p7 MEL/FEL files (other profiles too) - it triggers DV on my Sony A80J OLED.
The only weird thing I’ve noticed is the following: I downloaded a ton of test files to test out the different capabilities of the DV engine. The only one that is giving me trouble are the CMv4.0 mks/mp4s. Every CMv2.9 files I test (the ones with the red screen), all the trims appear to work.
However, with multiple CMv4.0 files I’ve tried, the 4.0 trims never appear to actually work on the first try. Meaning, I can only get the trim layer to show “CMv4.0 working” whenever I skip around the video file (usually they are 60s long). if I rewind the video 10 seconds, this can sometimes cause the 4.0 trim to appear; but again,if I play video from the beginning, it will only show the 2.9 trim red screen. This is the same whether I hook up the Ugoos directly to my TV, or using my Q990c receiver to passthrough the video (which it also does just fine). So whether it’s direct to the TV or passthrough’d the receiver, the output is still the same.
My Ugoos is in TV-LED mode.
Any idea why this is the case? i know 4.0 files are rare and only used for streaming mainly (I bought this device for remux p7 BL + EL capability) - but it’s still kind of bothering me when I’ve heard this device can properly decode 4.0 files. Which again, it clearly CAN - since I can trigger the trim to decode by skipping around the test file; but it never works when I just hit play. By the way, I’m just playing this video files directly off the “files” part of Kodi in CoreElec, connected to my Windows over Wi-Fi via SMB.
I doubt it’s the Wi-Fi though - I played A Quiet Place 2160p remux FEL and that played beautifully, and properly passthrough’d the TrueHD + Atmos to my surround sound
#10218 Post by RESET_9999 » Wed Aug 07, 2024 3:44 pm
He's probably talking about my cmv4.0 FEL TEST files.
https://drive.google.com/drive/u/1/fold ... nUvdZXqsY6
For some reason, it freezes when the player tries to read the cmv4.0 L8 trim with FEL. Most likely because it's a homemade FEL but if you try the other non-fel CMV4.0 test files, there is no issue with the ugoos.
And I watched tons of CMV4.0 FEL original movies and there's no such problem.
https://drive.google.com/drive/u/1/fold ... hM2pRX192e
deadchip12
#10219 Post by deadchip12 » Wed Aug 07, 2024 4:09 pm
RESET_9999 wrote: Wed Aug 07, 2024 3:44 pm And I watched tons of CMV4.0 FEL original movies and there's no such problem.
I would like to test to know if cmv4.0 is working properly on my Ugoos. Could you point me to the right files to use and what should I pay attention to on screen?
#10220 Post by RESET_9999 » Wed Aug 07, 2024 4:15 pm
cmv4.0 FEL test file that freezes: https://drive.google.com/file/d/1tFmjEc ... drive_link
cmv2.9 FEL test file that doesn't freeze: https://drive.google.com/file/d/1VZ7GXk ... drive_link
CMV4.0 non-fel test files (might not have an effect if your TV internal DV config is higher than 1000nits. I planned to do a 4000nits version eventually): https://drive.google.com/file/d/1o6ip_k ... drive_link
deadchip12
#10221 Post by deadchip12 » Wed Aug 07, 2024 4:29 pm
RESET_9999 wrote: Wed Aug 07, 2024 4:15 pm cmv4.0 FEL test file that freezes: https://drive.google.com/file/d/1tFmjEc ... drive_link
What about those cmv4.0 fel scenes from movies you posted above: https://drive.google.com/drive/u/1/fold ... hM2pRX192e. Can I use those to test? For example: Wonka (Real scene frame 30 000) CMV4.0 test P8.mp4. How do I know cmv4.0 is working just by looking at it?
#10222 Post by RESET_9999 » Wed Aug 07, 2024 4:39 pm
It depends. Some CMV4.0 dont have any L8 trims but the cmv2.9 bloc will always have L2 trims because of how Dolby works in a cmv4.0 workflow
IIRC wonka is just generated metadata, no manual trims were done for this movie so in this case it is normal to not see any cmv4.0 trim effect.
You can plot the file to determine if the cmv4.0 bloc has an active L8 trim. By active I mean a L8 trim that is not empty(set to 2048).
kazuma
#10223 Post by kazuma » Wed Aug 07, 2024 4:53 pm
RESET_9999 wrote: Wed Aug 07, 2024 4:39 pm It depends. Some CMV4.0 dont have any L8 trims but the cmv2.9 bloc will always have L2 trims because of how Dolby works in a cmv4.0 workflow
the movie migration is a CMV2.9 movie according your dovibat? how come?
for those who are interested: the conversaton (1974) is a cmv4.0 movie. P7 MEL (according to dovibat of reset_9999)
#10224 Post by RESET_9999 » Wed Aug 07, 2024 5:03 pm
kazuma wrote: Wed Aug 07, 2024 4:53 pm the movie migration is a CMV2.9 movie according your dovibat? how come?
Most of the movies are done in CMV4.0 but for the bluray disc releases they are converted from cmv4.0 to cmv2.9 which is why there is a workflow in dovi_scripts (2-3) that can bring the cmv4.0 back into the remux. If you have access to my google drive RPU collection, I already did all the work and most of the newer P7 remux now have cmv4.0 from web.
yes and the trims they did brightens more than the master which is a stupid thing to do because a 400nits tv will get a brighter DV presentation than a 1000nits TV.
https://slow.pics/c/cTDiL8Mn
kazuma
#10225 Post by kazuma » Wed Aug 07, 2024 5:22 pm
RESET_9999 wrote: Wed Aug 07, 2024 5:03 pm
Why they are restoring back to cmv2.9? What is the advantage to mux to cmv4.0?
#10226 Post by RESET_9999 » Wed Aug 07, 2024 5:37 pm
because cmv4.0 is how they were originally done. This is what the colorist saw on his grading monitor and the cmv2.9 is just a conversion. Theres no cmv4.0 bluray player so they dont deliver cmv4.0
Also, cmv2.9 has black crush issues but its not really visible with 1000nits REAL content.
cmv2.9 1000nits pattern(crushed): https://drive.google.com/file/d/1nmdDVE ... drive_link
cmv4.0 1000nits pattern(perfect): https://drive.google.com/file/d/1aNm-1E ... drive_link
Real content cmv2.9 1000nits: https://drive.google.com/file/d/1eQhqxs ... drive_link
Real content cmv4.0 1000nits: https://drive.google.com/file/d/1Cwb38U ... drive_link
Real content cmv2.9 10 000nits rpu (crushed): https://drive.google.com/file/d/1robA6t ... drive_link
Real content cmv4.0 10 000nits rpu: https://drive.google.com/file/d/10JNZdh ... drive_link
Ayibonakali
#10227 Post by Ayibonakali » Wed Aug 07, 2024 7:53 pm
SamuriHL wrote: Wed Aug 07, 2024 10:33 am There is very little chance it'll be useful for profile 7 fel. It's not impossible but extremely unlikely. I grabbed one just to play around with. I have a whole collection of useless streaming devices kicking around. Lol I don't hold out any hope that this will be a good device for local media.
Sent from my SM-S928U1 using Tapatalk
Hi Samuri I don't know If you are the same person of the AnyDVD forum, do you still have you tool, KeyDB Tool, I want to try It but I dont find the a working link. Thank you!
kazuma
#10228 Post by kazuma » Thu Aug 08, 2024 8:25 am
RESET_9999 wrote: Wed Aug 07, 2024 5:37 pm because cmv4.0 is how they were originally done. This is what the colorist saw on his grading monitor and the cmv2.9 is just a conversion. Theres no cmv4.0 bluray player so they dont deliver cmv4.0
So all movies are originally cmv4.0? Which workflow i need to use on your dovibat tool to convert remuxes to cmv4.0?
#10229 Post by RESET_9999 » Thu Aug 08, 2024 12:06 pm
kazuma wrote: Thu Aug 08, 2024 8:25 am So all movies are originally cmv4.0? Which workflow i need to use on your dovibat tool to convert remuxes to cmv4.0?
workflow 2-3 but you must have the matching web-dl and know how to resync a RPU.
Rororororo
#10230 Post by Rororororo » Tue Aug 13, 2024 7:35 pm
@RESET_9999
What does "MDP" mismatch mean?
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
