Dinosaurs Seaon1 and 2 DVD - cannot add create mkv files
dtallard
Post by dtallard »
Has anyone tried and successfully RIPed the TV Series 'Dinosaurs' ? I have a 4 DVD set of seasons 1 and 2 and it will not create mkv files for the actual chapter of the seasons. It only creates mkv files for extras like previews. See below: I set region on DVD player between disc one and disc two to no avail accept to eliminate the region warnings. I'm fully licensed as I use this all the time to add to my plex server.
MakeMKV v1.17.7 linux(x64-release) started
Backing up disc into folder "/srv/makeMKV.out/backup/DN10NNT1_7063.iso"
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Region setting of drive HL-DT-ST:BD-RE WH16NS40 does not match the region of currently inserted disc, trying to work around...
Backup failed
Cells 1-2 were removed from title start
Cells 9-9 were removed from title end
Title #1 was added (6 cell(s), 0:23:49)
Title #3 was added (6 cell(s), 0:22:59)
Title #4 was added (6 cell(s), 0:23:44)
Title #5 was added (6 cell(s), 0:23:41)
Title #6 was added (6 cell(s), 0:23:06)
Title #9 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 16-16 were removed from title end
Title #15 was added (13 cell(s), 0:06:33)
Cells 13-13 were removed from title end
Title #16 was added (10 cell(s), 0:10:21)
Title #17 has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 6-6 were removed from title end
Title #26 was added (3 cell(s), 0:13:23)
Title #27 was added (3 cell(s), 0:04:00)
Title #28 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-2 were removed from title end
Title #30 was added (1 cell(s), 0:02:23)
Title #31 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 10 titles into directory /srv/makeMKV.out
Failed to save title 0 to file /srv/makeMKV.out/title.mkv
Failed to save title 1 to file /srv/makeMKV.out/title_t01.mkv
Failed to save title 2 to file /srv/makeMKV.out/title_t02.mkv
Failed to save title 3 to file /srv/makeMKV.out/title_t03.mkv
Failed to save title 4 to file /srv/makeMKV.out/title_t04.mkv
5 titles saved, 5 failed
Saving 1 titles into directory /srv/makeMKV.out
Failed to save title 0 to file /srv/makeMKV.out/s01e01.mkv.mkv
0 titles saved, 1 failed
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
Calculated BUP offset for VTS #15 does not match one in IFO header.
Title #3 was added (6 cell(s), 0:23:18)
Title #4 was added (6 cell(s), 0:23:19)
Title #5 was added (6 cell(s), 0:23:36)
Title #6 was added (6 cell(s), 0:21:33)
Title #7 was added (6 cell(s), 0:22:59)
Title #26 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 was added (6 cell(s), 0:23:31)
Title #32 was added (6 cell(s), 0:22:39)
Saving 8 titles into directory /srv/makeMKV.out
Failed to save title 0 to file /srv/makeMKV.out/DN10NNT2_A7EE.mkv
Failed to save title 1 to file /srv/makeMKV.out/DN10NNT2_A7EE_t01.mkv
Failed to save title 2 to file /srv/makeMKV.out/DN10NNT2_A7EE_t02.mkv
Failed to save title 3 to file /srv/makeMKV.out/DN10NNT2_A7EE_t03.mkv
Failed to save title 4 to file /srv/makeMKV.out/DN10NNT2_A7EE_t04.mkv
Failed to save title 5 to file /srv/makeMKV.out/DN10NNT2_A7EE_t05.mkv
Failed to save title 6 to file /srv/makeMKV.out/DN10NNT2_A7EE_t06.mkv
Failed to save title 7 to file /srv/makeMKV.out/DN10NNT2_A7EE_t07.mkv
0 titles saved, 8 failed
Re: Dinosaurs Seaon1 and 2 DVD - cannot add create mkv files
Looks like the system is not letting you create the files. Do you have write privileges to /srv/makeMKV.out/ ?
dtallard
Post by dtallard »
Yes, I have all privileges but I just solved it. When I select just the episode chapter and the episode audio and eliminate all the subtitle chapters, it creates it. I can now do that 1 chapter at a time and add it to 'TV Shows'/Dinosaurs cdname/Season 01/s0xe0x-EpisodeTitle and it's found by the dvd database and plays correctly, don't need subtitles anyway. Thanks for the quick response.
