Despicable Me Blu-Ray PROBLEM!
Klevermind
Post by Klevermind » Sun Sep 11, 2011 10:19 pm
MakeMKV becomes non-responding every time I try to open my DESPICABLE ME Blu-Ray to rip it. I even tried ripping it with AnyDVD HD and then opening it with MakeMKV and it's still not working. I don't have AnyDVD HD running in the background, but MakeMKV still gives me the warning. I have attached a log file and hope someone will be able to help me out with this one...
MakeMKV_log.txt
MakeMKV log from DESPICABLE ME Blu-ray
(110.31 KiB) Downloaded 456 times
Re: Despicable Me Blu-Ray PROBLEM!
Post by mike admin » Mon Sep 12, 2011 12:22 pm
The log file shows that disc was opened successfully. Did you get to title selection screen?
Klevermind
Post by Klevermind » Mon Sep 12, 2011 5:57 pm
Thanks for the reply. No, it doesn't even get to that point. While opening the disc, my laptop's fan starts getting really loud and then when I click on the MakeMKV window it says (non-responding) next to MakeMKV.
Post by mike admin » Thu Sep 22, 2011 2:10 pm
Silly question, but try to let it work for 30 minutes or so - it might get through producing a quite big log file.
Klevermind
Post by Klevermind » Sun Sep 25, 2011 2:28 am
i will try that and post my results (log file). Thanks for your help.
zeus24
Post by zeus24 » Tue Oct 18, 2011 2:06 pm
I can confirm the problem. MakeMKV hangs and doesn't return. I try to let it run for 1 hour but it didn't produce any errors in the log file. MakeMKV can retrieve the info from the disc (see attached log), but cannot create a backup. It copies about 27 MB of files and then doesn't do anything anymore. The cpu load is around 3-5 %.
zeus
makemkv_backup.log
makemkv backup
(619 Bytes) Downloaded 409 times
makemkv_info.log
makemkv info
(110.7 KiB) Downloaded 421 times
