Vaako
Re: Pioneer firmware update February 2023
Do you happen to know if this drive has an flash chip ?
Than it would be possible to flash (downgrade) firmware before 12/2022.
Tomorow I will check the drive internaly if I can find some kind of flash chip.
Read your PM.Vaako wrote: Fri Aug 02, 2024 10:52 pm Do you happen to know if this drive has an flash chip ?
Vaako
I have the firmwares from version 1.03 to 1.05 (versions 1.01 and 1.02 I could not find them)
Which one do I have to get installed that is before 12/2022 ?
BDR-212EBK / ULBK (BDR-2212)
ver. change point
1.05 Added a new function "Fragile disc mode for music CD" Improved operational stability
1.04 Improvement of the playback operation with specific media
1.03 Improvement of the playback operation with specific media
1.02 Improvement of the playback operation with specific media
1.01 Support New BD-R TL media(4x Writing : RiTEK) Improvement of the operational stability when BD-R SL 16x speed recording.
Improvement of the operational stability when recording CD, DVD, BD.-
You need a drive that is lower/ equal 1.02. If the firmware is newer, it will be encrypted and older firmwares can't be flashed to the drive.Vaako wrote: Sun Aug 04, 2024 12:15 am I have the firmwares from version 1.03 to 1.05 (versions 1.01 and 1.02 I could not find them)
BDR-212EBK / ULBK (BDR-2212) ver. change point 1.05 Added a new function "Fragile disc mode for music CD" Improved operational stability 1.04 Improvement of the playback operation with specific media 1.03 Improvement of the playback operation with specific media 1.02 Improvement of the playback operation with specific media 1.01 Support New BD-R TL media(4x Writing : RiTEK) Improvement of the operational stability when BD-R SL 16x speed recording. Improvement of the operational stability when recording CD, DVD, BD.
Vaako
Does someone have this firmware 1.02 for the BDR-212 because I can not find it.
Update: nevermind I have found the file "BDR-212EBK_UBK_FW102EU.exe"
Now I got to figure out how to extract firmware from the executable and use a DOS flasher to force the flash.
Any advice/recommendations on this are very welcome !
You can't!Vaako wrote: Mon Aug 05, 2024 10:07 pm Does someone have this firmware 1.02 for the BDR-212 because I can not find it.
Killertamagotchi
I guess I also have the problem that you can no longer make it UHD compatible?
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-213M
Revision: 1.04
Serienummer: *****************
Firmware-Datum: 2022-12-12
Highest AACS version: 77
Drive platform: Pioneer RS9200
Firmware version: ID56
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.04
Unfortunately you are correct. Not possible.Killertamagotchi wrote: Tue Aug 06, 2024 6:57 pm I guess I also have the problem that you can no longer make it UHD compatible?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.04
Killertamagotchi
hmm at least I can send it back to Amazon
Let us know your country of residence for new options.
Killertamagotchi
Its Germany
PM sent.Killertamagotchi wrote: Tue Aug 06, 2024 10:44 pmIts Germany
Rurido
Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Here's the info from MakeMKV:
Any help is much appreciated
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: ~
Firmware-Datum: 2017-04-18
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.10/ID22
Keine Disk eingelegt
PM sent.Rurido wrote: Wed Aug 07, 2024 2:57 pm Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Here's the info from MakeMKV:Any help is much appreciatedCode: Select all
Laufwerksinformation OS-Gerätename: \Device\CdRom0 Aktuelles Profil: BD-ROM Produzent: ASUS Produkt: SBW-06D2X-U Revision: 1.10 Serienummer: ~ Firmware-Datum: 2017-04-18 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.10/ID22 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Keine Disk eingelegt![]()
Rurido
It worked, thanks a bunch! Though one question, the read speed seems to be quite low for UHD disks (around 0.2x-1.3x), is this normal?
