FULL BACKUP: DEBUG Code Mission:Impossible FALLOUT UHD and Tomb Raider UHD
Bandito
Post by Bandito » Mon Aug 05, 2024 4:28 pm
i will make a complete Backup from a UHD BD from Mission:Impossible FALLOUT
Is that OK, or has he a problem.
I found this DEBUG Code there, but in the moment he is still Backuping this disc.
MakeMKV v1.17.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Stefa/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Backing up disc into folder "D:/Video/backup/UHD MISSION IMPOSSIBLE FALLOUT"
DEBUG: Code 4278268161 at eP4E'9IxPe4XXL<dp:29398530
This Morning i make Backup from UHD BD Tomb Raider.
The finished LOGGING FILE looks like this:
Debug log started at Mon Aug 05 04:21:54 2024 , written by MakeMKV v1.17.7 win(x64-release)
001005:0000 MakeMKV v1.17.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Stefa/MakeMKV_log.txt
No SDF v098: HL-DT-ST_DVDRAM_GHC0N_WF01_201509011433_710HC009302
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF id v098: HL-DT-ST_DVDRAM_GHC0N_WF01_201509011433_710HC009302
SDF v098: ASUS_BW-16D1HT_3.10_211901041014_KLQL6DB4551
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
005072:0000 Backing up disc into folder "file://H:/Video/backup/UHD TOMB RAIDER"
DEBUG: Code 2147483648 at vtE<(>?]*E!<z7r!:121265499
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Mon Aug 05 05:05:23 2024
Is that OK, or was it demaged?
The UHD Disc a totally NEW.
Never played before.
NO DUST, NO FINGERPRINTS OR SCRATCHES.
Re: FULL BACKUP: DEBUG Code Mission:Impossible FALLOUT UHD and Tomb Raider UHD
Post by dcoke22 » Mon Aug 05, 2024 7:03 pm
Yeah, it is fine. As a general rule of thumb, if MakeMKV finishes and produces a file, it is good. If it encounters a problem, it does not produce a file.
Bandito
Post by Bandito » Tue Aug 06, 2024 4:50 am
dcoke22 wrote: Mon Aug 05, 2024 7:03 pm Yeah, it is fine. As a general rule of thumb, if MakeMKV finishes and produces a file, it is good. If it encounters a problem, it does not produce a file.
Many Thanks for the Feedback / reply.
