Burning blank BR discs for friends from MKV files. Cinavia protection.
ryanb0517
Post by ryanb0517 »
I haven't seen a thread on this in 2024.
I bought a 50-pack of blank BR-D for burning movies for my friends who have blu-ray players. I understand the whole Cinavia watermark in the audio track that mutes the movie and gives a message 3 error.
I burnt a movie for a friend from a MKV file by using Blu-Ray Creator on DVDFab13 to an .ISO and then burning the .ISO to a disc with ImgBurn.
This blu-ray was made by Lionsgate and it's giving me a message 3 error on both his blu-ray and my blu-ray player.
Is there a workaround for this in 2024? I'd like to make some copies of blurays.
Thanks in advanced.
Re: Burning blank BR discs for friends from MKV files. Cinavia protection.
ryanb0517 wrote:
Mon Aug 05, 2024 11:23 pm
Thanks in advanced.
Piracy (which is what you are doing) is not condoned here.
If you must, don't write discs. Just give them the mkv file on a USB thumb drive. Also, the player being used could be the problem. Anything from Sony (maybe some others) will have the Cinavia detection rubbish in it.
ryanb0517
Post by ryanb0517 »
Sorry for that, I didn't mean to break the terms. Thanks for advising me.
zaqqaz6917
Post by zaqqaz6917 »
Many years ago I used to archive my bluray disks by burning copies and overcame the cinavia problem by using a bluray player that came out before cinvia was implemented as these pre-cinavia players don't have the required chip or whatever
Pre 2011
