MakeMKV would not work on this disc.
MakeMKV v1.6.14 win(x64-release) started
Downloading latest SVQ(s) to C:\Users\xx/.MakeMKV ...
Loaded 23 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
Failed to process BD+ code using generic SVQ from builtin/00002.svq
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\xx/.MakeMKV/dump_X-Men__First_Class_FE93A37674645E75.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Dump file attached.
How long does it usually take for a new SVQ file to be created ?
So I have an idea as to when to check back for the update so I can create the file ...
Thanks ...
BlueRay : XMen First Class
- dump_X-Men__First_Class_FE93A37674645E75.tgz
- (985.19 KiB) Downloaded 395 times
- Contact:
Re: BlueRay : XMen First Class
A new protection, see http://www.makemkv.com/forum2/viewtopic.php?f=8&t=4063
