if the workflow for injecting stream's DV cmv4.0 into bluray's DV cmv2.9/HDR10 is any different.
it's not
2) Workflow 2-4 in the old version is used to find frame difference between the bluray and stream file, but now it's no longer there? What is the workflow now?
it's now workflow 9-1
deadchip12 wrote: Mon Aug 05, 2024 3:26 am 1) Workflow 6-4: now running it with the stream video file produces additional 2 graphs which are L8.HUE.Vector.Field.PLOT and L8.Saturation.Vector.Field.PLOT. What are these used for?
They are the extra control for color saturation and hue in cmv4.0. Used mostly for fine-tuning the colors in 100nits trim pass.
Rororororo
Post by Rororororo »
RESET_9999 wrote: Sun Aug 04, 2024 8:09 pm
Rororororo wrote: Sun Aug 04, 2024 6:16 pm Would be possible to add an option for batch extraction or metafier procceses etc?
I think you can already do that.
if you input a folder and select ''E'' in Mode.I (1), it should redirect to the batch L1 plotter workflow (6-3) which can batch extract.
metafier: no
Yeah, I tried that before posting and it didn't work in both 3.0.0 and 3.0.1, only extracted from the first mkv in the folder
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
It works in the latest beta, I just tried it.
deadchip12
Post by deadchip12 »
RESET_9999 wrote: Mon Aug 05, 2024 3:54 am
it's not
Thanks. What is the workflow for exporting scene cuts now? It was 2-3 before.
2-1 or 1-s
deadchip12
RESET_9999 wrote: Tue Aug 06, 2024 12:54 am 2-1 or 1-s
Thanks again. Btw, I see John Wick Chapter 4 is put in the red table. Have you tested it for the green table? I see Super Mario Bros 2023 in both red and green table.
I dont add the cmv4.0 metadata that cannot be transferred in this list. JW4 is in the red list because it expands brightness as the note says and this has nothing to do with the cmv4.0 transfer.
If the web metadata and bd are the same, it can be transferred regardless of if fel expands brightness or not which is why Mario bros is in both sections. It expands brightness but also the same metadata as the web.
BTW, the movie ''IF'' that just came out, has the mostly same L1 but they completely redid the trim pass for the bluray:
https://slow.pics/c/p3EChIcg
mreastman
Post by mreastman »
Google is dropping a new 4k streaming device: https://store.google.com/us/product/goo ... r?hl=en-US
Gigabit ethernet, 32gb storage, 4gb memory, and support for atmos.
Now we wait to see if it supports DL DV & MEL/ FEL...
deadchip12
mreastman wrote: Tue Aug 06, 2024 2:34 pm Google is dropping a new 4k streaming device: https://store.google.com/us/product/goo ... r?hl=en-US
Oh come on I just replaced the x700 with the Ugoos lmao. And this thing only costs $100?
But given google's track record with the chromecast, i don't have much hope.
deadchip12
What does HYBRID in the title mean? For example: Tenet.2020.UHD.BluRay.2160p.DTS-HD.MA.5.1.DV.HEVC.HYBRID.REMUX-FraMeSToR. Is it hdr10 bluray version with DV already injected from web version? Meaning we don't have to do it ourselves?
kazuma
Post by kazuma »
deadchip12 wrote: Tue Aug 06, 2024 10:59 pm
There are also other questions like audio passthrough. We'll wait and see.
But beside that, i will only buy stuff that is fully tested by reset_9999 :P
Post by SamuriHL »
There is very little chance it'll be useful for profile 7 fel. It's not impossible but extremely unlikely. I grabbed one just to play around with. I have a whole collection of useless streaming devices kicking around. Lol I don't hold out any hope that this will be a good device for local media.
Sent from my SM-S928U1 using Tapatalk
kazuma
Post by kazuma »
Which movies are cmv 4.0?
deadchip12
A user from CoreELEC forum just posted this:
TLDR: CMv4.0 bug
Hey all - quick question.
I just received my AM6B + yesterday with the n firmware installed from the factory.
I installed the CoreELEC-Amlogic-ng.arm-21.1-Omega_nightly_20240804-Generic.img.gz without incident, utilizing dual boot, and was able to install the updated plexmod, etc etc.
All appears to be well. Everything appears to play just fine, dolby vision p7 MEL/FEL files (other profiles too) - it triggers DV on my Sony A80J OLED.
The only weird thing I’ve noticed is the following: I downloaded a ton of test files to test out the different capabilities of the DV engine. The only one that is giving me trouble are the CMv4.0 mks/mp4s. Every CMv2.9 files I test (the ones with the red screen), all the trims appear to work.
However, with multiple CMv4.0 files I’ve tried, the 4.0 trims never appear to actually work on the first try. Meaning, I can only get the trim layer to show “CMv4.0 working” whenever I skip around the video file (usually they are 60s long). if I rewind the video 10 seconds, this can sometimes cause the 4.0 trim to appear; but again,if I play video from the beginning, it will only show the 2.9 trim red screen. This is the same whether I hook up the Ugoos directly to my TV, or using my Q990c receiver to passthrough the video (which it also does just fine). So whether it’s direct to the TV or passthrough’d the receiver, the output is still the same.
My Ugoos is in TV-LED mode.
Any idea why this is the case? i know 4.0 files are rare and only used for streaming mainly (I bought this device for remux p7 BL + EL capability) - but it’s still kind of bothering me when I’ve heard this device can properly decode 4.0 files. Which again, it clearly CAN - since I can trigger the trim to decode by skipping around the test file; but it never works when I just hit play. By the way, I’m just playing this video files directly off the “files” part of Kodi in CoreElec, connected to my Windows over Wi-Fi via SMB.
I doubt it’s the Wi-Fi though - I played A Quiet Place 2160p remux FEL and that played beautifully, and properly passthrough’d the TrueHD + Atmos to my surround sound
He's probably talking about my cmv4.0 FEL TEST files.
https://drive.google.com/drive/u/1/fold ... nUvdZXqsY6
For some reason, it freezes when the player tries to read the cmv4.0 L8 trim with FEL. Most likely because it's a homemade FEL but if you try the other non-fel CMV4.0 test files, there is no issue with the ugoos.
And I watched tons of CMV4.0 FEL original movies and there's no such problem.
https://drive.google.com/drive/u/1/fold ... hM2pRX192e
