Rororororo
Post by Rororororo »
RESET_9999 wrote: Sat Aug 03, 2024 12:23 am
Rororororo wrote: Fri Aug 02, 2024 10:08 pm I'd at least separate them with spaces rather than slashes, swap the value with the description and use one letter case.
this should be better:
That's better IHMO.
Would be possible to add an option for batch extraction or metafier procceses etc?
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Rororororo wrote: Sun Aug 04, 2024 6:16 pm Would be possible to add an option for batch extraction or metafier procceses etc?
I think you can already do that.
if you input a folder and select ''E'' in Mode.I (1), it should redirect to the batch L1 plotter workflow (6-3) which can batch extract.
metafier: no
deadchip12
Post by deadchip12 »
@RESET_9999
I'm trying the latest version of Dovi_Scripts to see if the workflow for injecting stream's DV cmv4.0 into bluray's DV cmv2.9/HDR10 is any different. Have a few questions:
1) Workflow 6-4: now running it with the stream video file produces additional 2 graphs which are L8.HUE.Vector.Field.PLOT and L8.Saturation.Vector.Field.PLOT. What are these used for?
2) Workflow 2-4 in the old version is used to find frame difference between the bluray and stream file, but now it's no longer there? What is the workflow now?
Would be great if you can update the tutorial videos. Thanks.
it's not
it's now workflow 9-1
deadchip12 wrote: Mon Aug 05, 2024 3:26 am 1) Workflow 6-4: now running it with the stream video file produces additional 2 graphs which are L8.HUE.Vector.Field.PLOT and L8.Saturation.Vector.Field.PLOT. What are these used for?
They are the extra control for color saturation and hue in cmv4.0. Used mostly for fine-tuning the colors in 100nits trim pass.
Rororororo
RESET_9999 wrote: Sun Aug 04, 2024 8:09 pm
metafier: no
Yeah, I tried that before posting and it didn't work in both 3.0.0 and 3.0.1, only extracted from the first mkv in the folder
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
It works in the latest beta, I just tried it.
deadchip12
RESET_9999 wrote: Mon Aug 05, 2024 3:54 am
it's not
Thanks. What is the workflow for exporting scene cuts now? It was 2-3 before.
2-1 or 1-s
deadchip12
RESET_9999 wrote: Tue Aug 06, 2024 12:54 am 2-1 or 1-s
Thanks again. Btw, I see John Wick Chapter 4 is put in the red table. Have you tested it for the green table? I see Super Mario Bros 2023 in both red and green table.
I dont add the cmv4.0 metadata that cannot be transferred in this list. JW4 is in the red list because it expands brightness as the note says and this has nothing to do with the cmv4.0 transfer.
If the web metadata and bd are the same, it can be transferred regardless of if fel expands brightness or not which is why Mario bros is in both sections. It expands brightness but also the same metadata as the web.
BTW, the movie ''IF'' that just came out, has the mostly same L1 but they completely redid the trim pass for the bluray:
https://slow.pics/c/p3EChIcg
mreastman
Post by mreastman »
Google is dropping a new 4k streaming device: https://store.google.com/us/product/goo ... r?hl=en-US
Gigabit ethernet, 32gb storage, 4gb memory, and support for atmos.
Now we wait to see if it supports DL DV & MEL/ FEL...
deadchip12
mreastman wrote: Tue Aug 06, 2024 2:34 pm Google is dropping a new 4k streaming device: https://store.google.com/us/product/goo ... r?hl=en-US
Oh come on I just replaced the x700 with the Ugoos lmao. And this thing only costs $100?
But given google's track record with the chromecast, i don't have much hope.
deadchip12
What does HYBRID in the title mean? For example: Tenet.2020.UHD.BluRay.2160p.DTS-HD.MA.5.1.DV.HEVC.HYBRID.REMUX-FraMeSToR. Is it hdr10 bluray version with DV already injected from web version? Meaning we don't have to do it ourselves?
kazuma
Post by kazuma »
deadchip12 wrote: Tue Aug 06, 2024 10:59 pm
There are also other questions like audio passthrough. We'll wait and see.
But beside that, i will only buy stuff that is fully tested by reset_9999 :P
Post by SamuriHL »
There is very little chance it'll be useful for profile 7 fel. It's not impossible but extremely unlikely. I grabbed one just to play around with. I have a whole collection of useless streaming devices kicking around. Lol I don't hold out any hope that this will be a good device for local media.
Sent from my SM-S928U1 using Tapatalk
